HI ALL, I AM NEW TO THIS SITE, BUT NOT THAT NEW TO THE 300ZX. I HAVE HAD MINE FOR ABOUT 3 YEARS AND I LOVE IT. I WANT TO CHANGE MY STEERING WHEEL TO SOMTHING A BIT SMALLER AND A BIT BETTER LOOKING, BUT I CAN NOT FIND ANY LISTINGS OF A BOSS THAT WILL FIT A Z32, I WOULD LIKE TO KEEP MY 4 WHEEL STEERING THINGY UNDER THE STANDARD WHEEL, ANY IDEAS WOULD BE WELCOMED. MY SECOND PROBLEM IS THAT MY Z RUNS OK WHEN IT IS COLD BUT IF YOU STOP AT A PETROL STATION TO FILL UP, WHEN YOU START THE CAR AND SELECT DRIVE ON THE AUTO IT STALLS. THEN IT IS VERY HARD TO START AGAIN.ANY IDEAS??????? PLEASE!!!!!!!!!
I think Momo sells wheels that fit the Z, I'm not sure if you can keep the HICAS though.
About the stalling problem: you might want to try to set the idle a little bit higher.
It can also be that your TPS (throttle position sensor) needs to be replaced or readjusted.
-Eric
Warning!! my car came with a slightly smaller steering wheel made by Tomei from Japan it looks good but I cant see much of the clocks because of it which is slightly annoying.
Paul
Oh oh, don't want to alarm you but that's what mine was doing, turned out to be a shagged engine which I'm in the process of sorting out. Hopefully a full re-build!
Hope yours is something simple like TPS just needs cleaning out. If you want to know how to do this, check out tech section and FAQ's on twinturbo.net...excellent site!
you can get a steering wheel hub by Abflug who sound german but is jap i think. Search on twinturbo.net for more details. Its about £50 plus shipping etc. Someone else does one also but I can't remember the name. The hubs fit most Momo wheels.
thanks but I cant seam to find anywhere that sells these boss things, any ideas?
