what about these injectors?
  • Replies 65
  • Views 1.6k
The deustchwerks injectors are ok but why faff around with resoldering the loom and fitting an adaptor kit when it doesn't cost much more for nismo and any ecu you get will not be tuned for these exact injectors?
the dw are not a direct replacement?
No, not unless your car is series 4!
ah i didnt know you had to fook about with adapters.
Think im guna go for the 480cc they are more than enough for me and im on a budget :)
and at least they are nismo.
The minimum u want are 550, I would personally direct the money towards getting the turbos professinally reconned and go to scholar engineering to get your stock injectors reconned, you don't need to take the engine out to swap injectors, and you can upgrade at a later date?
Thats sound advice topless, think il leave the injectors for a later date.
And concentrate on the the tubs and engine for now.
how much do injector recon cost
Injector recon by scholar is about £100 in total, delivered back to your doorstep!
hmm id rather spend the £100 on new ones.
did you just see the previous post topless about them 555 nismo injectors for 240 quid?
Ok now im confused....
What exactly would i need to fit these?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=300205738767&ssPageName=STRK:MEWA:IT&ih=020
Can i dremel the plenum.. not me personally tho :S
They are second hand injectprs for 94 onward Z32. You would need the later style fuel rail, late style connectors and later style lower plenum.
You would also want to get themm flow tested before fitting as they are used.
I've been tempted by the Deutchwerks for a while now. £200 cheaper than Nismo's and with a decent reputation.
Im tempted by the Deutchwerks. £200 cheaper than Nismo's
but are they a good make?
and they also need lower plenum (or dremel jobby) connectors and fuel rail?
coz if ya decided to bigger again later down the line you wouldnt have to faff about again i guess
you just need the adaptor kit they supply.
Have always recomended and fitted Nismo's on others peoples cars but I like saving money myself where I can lol
I have'nt decided if I would buy those or just get the Nismo's....or if I would get any at all in fact, this is suppossed to be my tempoary engine till the vh45 is ready....but I get easily carried away :slap:
