HID's
Well Finally got round to fitting Dannys HID kit, to say i'm impressed is an understatement, The ease of installation of this kit is amasing!! I had the bumpwer off as i was fitting the mesh so thought i'd do the HID's while i was at it, as the ballests cause a bit of a prob with location, i ended up putting them on the inside of the nose cone section, under the vents that was there is no way of them over heating.
I found it easier to take the lights them selves iut to aid in putting it all together.
a few little pictures for you....
Light with normal bulb... notice the yellowish tinge...
Now a HID bulb...mmmm nice and white...
At night with HID's on and the LED side light bukbs that Danny supplies...
Another one but with the Fog lights as well..... light are bright than the fogs now!!!
I now have to re wire the di, dip system, of which i did have a write up but had to format my system... and lost, so if any one does have that, i know i sent a few copies out, i'd appreciate it...
Neil
Thanks for that, but it's in word pad and i cant read it, or print in out... has any one got a copy in Word or PDF format?
Neil
Neil
Oh well i tried :wack:
Might be worth trawling through past threads, if no-one reading this has it to hand :)
Just found it in my documents but its word pad again :wack:
Do you know anyway i can change it and send it to you, i don't know jack about this kinda thing btw.
open it in word pad and copy and paste into word. You should be able to open the document from word. Then resave as .doc extension.
Just managed to copy and paste it into Microsoft Works Word Processor - is that any good to you, if so how do i sent it to you?
Please explain VERY slowly how to do that and i will :) Cheers
UPDATE :wack: :rofl:
No luck i'm afraid, just saves it as Word Pad again, sorry bud, i'm sure someone can help you out :)
