i checked my timing the other day and thought it was ok, my bro in law (mechanic) came today and he checked, it was 27 degrees out, ow its been set to 15 degrees and it seems slower at top end of the rev range, it seems to pull more low down, also checked my base idle which i also done wrong, its now set correct, the stalling from pull off is still there though
checked all plugs and they are all burning correctly, no sooting and gaps were spot on, checked all connectors and they are ok
should i set it back to 27 degrees out as i dont like the way it drives now, also i set the idle after i changed the timing
the bolts on the cas aint in the middle anymore, they are more to the left of the holes, is this right
have i done everything ok, do i need to reset ecu now to get it to recognise that the timing has been altered???
cheers in advance
Allan
