suspension arm ebay warning!!
if you are thinking of upgrading your front lower arms DO NOT BUY THESE.
i brought these and had to modify them just to get them to fit correctly. the shortest setting is longer than the OEM arms, and to cap it off THE DRIVERS SIDE ARM SNAPPED!! luckly i was not traveling at high speed so no other damage occured.
PLEASE THINK TWICE BEFORE BUYING THEM!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=130197387503&Category=40192&_trksid=p3907.m29
SPL or Powertrix for me only. Tried and tested and both well built. Something as critical as that needs to be a really good part.
Yikes!
Where did you bring them??? :tongue:
I know....you tried to resist posting , but ya caved in to the pressure :rofl:
i took them straight to the skip just up the road :tongue:
how much are them old girls mark?
$612 from concept Z not sure on postage as their a part of a large shipment
Hmmm not sure how they can fit both S13 and S14 as both are different. I know the length can be adjusted but the ball joint in an S14 arm is loads longer than an S13 one. You cant swap either as an S14 ball joint is too long for a 13 and a 13 ball joint doesn't go through the knuckle on a 14. Steer clear.
Ivan
