Anybody Spot my car today?
Heading North on the M5 on the back of a tow truck. Could have easily been mistaken for a skip from what ive been told. :(
its black BTW and not silver like my sig
  • Replies 34
  • Views 1.1k
Its having an assesment over the next couple of weeks, when i get the mechanics report back i will see what to do. If its saveable it will be saved, but I'm not going to waste a mechanics time trying to polish up a turd LOL
Car arrived
dont know why you have to click link to see pics the have the  and tags
please note picture taken at place where work is to be done and not at the place where any of the previous work was done
you would have thought the gbox would have been put back together
prefer those wheels on there now than those 19s bud
hope it gets sorted.!!
Ye nice wheels ;)
1st part of assesment. Quite a lot to do there me thinks.
Mechanical
Rear shock absorbers securing nuts loose at the top in the boot area
N/S outer hicas bush and inner hicas steering arm bush worn ( MOT failure)
O/S turbo bolts missing
Gaskets / sealant missing from both down pipes where they meet the turbo elbows
Missing exhaust downpipe flange nut
Small section brake pipes to the rear calipers need replacing
Front brake calipers are seized on
Gear lever support bracket missing
Exhaust heat shield missing
Other
Front N/S tyre tread below legal minimum limit ( MOT failure )
Front O/S tyre tread close to legal minimum
Paint work very dull and needs a good cut and polish
A quick check over the engine has thrown up a couple of issues where it looks to have some pipes not connected correctly and some mixed up
and there is more
Dump valves not connected ( no recircs either)
Air con outside sensor missing
Knock sensor failed
Air leaks on engine plumbing
Wrong spark plugs fitted
Idle speed incorrect set up
Throttle and cruise control cables too tight
Aiv supply pipes mixed up at throttle
Brake fluid low
Battery clamp missing
Fuel filter bracket bolts missing
Front shock absorbers both loose at top mounts
o/s head lamp very poor beam ( incorrect bulb fitting)
Steering wheel centre rubber pad pealed back
Small corrosion patch on O/S inner wing top
Cooler bracket insufficient
Undercoating cleaning of surfaces etc
Best of luck, which ever chioce you decide on. It would be a shame to see a SW zed die. :cry:
Dont break her , yeh its a long list, but nothing serious or costly there to sort out.
Have you had a report about the corrosion ? - Thats the real concern.
The rust patch on the inner wing should be a concern. From experience once you start cleaning it up ready for welding, that word 'small' gets smaller and turns into 'big', job that is. Suspension out and inner wing mounted items removed to effect a good repair. Is this car better than your last Zed that you broke, or by the sounds of it worst. Your not having much luck Marcus by the sounds of it. Out of the frying pan into the fire springs to mind.
Corrosion / welding issues
O/S Front sill ( Impact or poor jacking damage and heavy corrosion )
O/S Rear sill ( Very bad corrosion, holed through to rear quarter area)
N/S Front sill (Impact or poor jacking damage and heavy corrosion )
N/S Rear sill ( Very bad, holed through to inside car and rear quarter area)
Front radiator support ( pitted )
Rear bumper support O/S ( small area of corrosion)
Rear diff area ( heavy surface rust)
This car is 10x worse than the silver one i broke, worse thing is a lot of thinks required for this car were actually replced on the silver car before it was scrapped, like the HICAS arms and brakes :(
I think that unfortunatly its time to break it, lots of time involved in sorting that lot out which = £££££££. Throwing good after bad. Get what you can in parts and go buy a nice one, a lot less hassle and stess as well mate
TBH you'll probably get enough money breaking and selling the parts to buy another one anyway.
Just make sure you get a good one this time ;)
hang on...before jumping down the Breaking route...have you had quote to sort out the corrosion....at the end of the day it all comes down to price.
