1) size of speakers in the car - yes all of them
2) Where can i feed my amp wire thru
3) In the uk cars do they have the wiring for the double din (ie 2 Cd players)
4)Carbon doors and carbon wings - i know bonnet and boots availible
5) can i have 2 boost gauges - 1 for each turbo
6) fmic yeh or no
7) Roll Cage availible ???
I don't think so - the balance bar on top of the plenums evens out boost pressure in the whole system IIRC.
As for the other questions.....pass!
Richard :smw:
Answers
1: rear speekers = 6"x4" front= 5"
2: pasanger foot well bottom left hand side
3: dont know I have a jspec
4: Grp vipper wings @ Zcentre
5: No, the system is ballanced so if you had 20 they would all read the same.
6: Front mount is avalible all over the place (Do a search) Greedy, HKS, Z1
7 Rollcage some have but think they are custom and not off the shelf
Hope this helps
Allan
uk has wiring for one cd player/radio cassete player but you could link 2 together by using rca(phono) leads depending on cd players used ( one will need aux out the other aux in)
big discussion on fmic or smic, general concensus is up to 500hp use upgraded side mount, above that fmic, or fmic if you want to pose
cheers
what i been looking at is a few mods and audio wise it was going to be a jvc flip up screen with built in freeveiw(its just a screen) and then going to use a jvc kd-avx2 as main hu with its dvd player on it
thanks again all my queries awnsered
also who was it who does the blue led controls ???
5. Yes you could. Although the two sides are balanced the pipe is very small compared with the volume of air that could be flowed by the turbos.
6) fmic yeh or no
regarding your two sterio question scrap that idea !go to ebay type CARPUTER i think you will be pleasently surprised??? here's 1 item nomber you should look at 130179641591 newdashmo-1195159551-471.jpg
