Hi peebs.
Now I have a set of wheels for my car but im not sure if they are going to fit.
The rears have 285 with tyres which i think is just over 11 inches. I know people have these so that by itself would not be a problem.
now here is the main problem... they are 100pcd. I have with alot of searching found and adaptor that will convert my 114.3 hub to 110pcd wheels, but its 1 inch thick. Now added to the fact these wheels are wide, does anybody think they will fit?
Here are the wheels by the way.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140110621022
I know most of you hate 3 spoke wheels but i like em and they have a really nice wide dish on them :)
they wont fit bud at least not safely IMO
Is that due to the adaptor possibly being to weak or wheels being to wide?
problem is your extending an already wide wheel further out over the arch, might be ok with a widearch conversion, after you spend all that money you could get a set of advans and be done with it bud.
doh cant afford the wide arch or advans lol. ok back to the drawing board
cheers for the advice greg.
Depends on the offset ! Marcus, I remember offering up the wheels to the car a while back and it looks like we had room to play with the arch clearance....but without fitting with the spacers Im not sure of a definate answer.
they won't fit mate. not without rolling the arches. However, are the spacers thick enough that you could have them milled down so that there not as thick??
That ad says 5 stud i recon they are 10" rear and 9" front .The wheels need to be measured with tyre off from the inside of the tyre bead [rim].If the offset are 35 ish and you change the rear tyre to 265 or 255 they stand a good chance to fit .Just looked at ad again does he mean they are 5x100pcd .
no idea why they are split width and pcd 100 as i dont know any rear wheel drive cars that are pcd 100
ill have to get somebody to measure them. as i cant get to where they are stored atm due to work.
The other option if it's close is to get the arches rolled - this would probably cost around £100
