rear spoiler
help!, i have the original rubber rear spoiler which the last owner destroyed by using a power washer on removing the paint, is it possible to obtain a replacement ? how easy are they to remove ? what do you recommend?
thanks Gary
fibreglass replacement can be had from the zcentre, and these wont soak up water and flake off the paint. Origonal one is a bitch to remove.
removing rear spoiler click here you will need to remove the trim around the inside of tail gate first before you unbolt the spoiler, but if it was anything like mine the bolts where rotten anyway, the hardest part was getting it unstuck from the body
not looking forward to the task, but its a must as the original is leaking into the rear
thanks for the info. Which spoiler would you recommend?
1 i got :D the Viper zc019.jpg but the rest will say the 99 spec or go smooth
99 spec rear spoiler below for your veiwing pleasure
Did you use the tailgate lower skin with the viper spoiler?
yes its got the tail gate skin on it as well, only as it was already done when i got the car, it was smooth and i just added the spoiler over it, but you dont have to use the tail gate skin you can fill and paint the holes and just get the perspex strip for the back edge of tail gate
how it looks once spoiler taken off
filled, painted and perspex strip added
where would you suggest the best place is to get the tail skin from and does it incorporate the brake light?
The skin from Zcentre does not, but the patern rear spoiler does.
RainbowZ has fitted a high level brakelight to his tailgate skin and it looks great.
