Need Radiator
Looking for a rad for my 2+2 UK TT auto, mines just started leaking from a pin hole somewhere on bottom left passenger side, aint got the time to start soldering with thick solder lead so need either a known working replacement or an upgrade one with the external oil cooler..
Can anybody help - West Yorkshire :hurl:
Probably should have put this in Items Wanted section but anyway does your auto rad look like this one?
If so I don't fancy your chances of getting an OEM replacement, I have being trying for sometime. However I now have an auto rad with only two pipes, as in next diagram, and I going to get two longer oil pipes and discard the rail at the bottom that splits them to both sides.
that aint the same as my auto rad, which only has 2 oil lines on the right side. That UK or import?
what the hell is the 2 pipes on the right for i wonder :confused:
That is on my UK. It has a twin rail metal pipe mounted below rad which splits and enters radiator on both sides.
