April 13, 200718 yr car has failed MOT on 3 sections on the sills where jacking points are can you buy full sill outer sections? or is it just a case of cutting the rot out and replacing it with new? its also failed on 3 brake pipes that disapper under the rear sub fame. is the sub frame easy to remove? its a uk spec tt by the way Thanks Si
Si
