Apexi Multichecker and Conzult ?
Because i like wizzy displays ive got an Apexi multichecker of ebay. Now as the apexi manual suggests i will connect the multichecker loom to the ECU loom with those blue halfords cable splitters... so as i can still plug a conzult in can i use both at the same time or is this dangerous?
yes, multichecker and conzult work fine together
Right had a look in the passenger footwell where the ECU box is. Loads of wiring looms. Is there a loom i can disconnect and remove to solder the APEXI loom to. Or do i have to do something with the ECU box?
I really hope i dont screw up my zed on xmas day arf!
i ust put in an apexi multi checker, it's the big connetor, think there are about 11 wires to do, i used heat shrink as well,tok me about 45 mins to do.
if you do aserech under my name, there's a post about this it should give you all the info you need.
Neil
Cant find any apexi multichecker posts under Darkside TT :(
.. well i mean anything that tells me how to get looms out for soldering, etc
sorry mate it's the ecu pin layout thread under my name you need, it's on the first page
Neil
I need tips on how to remove that feckin huge connector from the right side of the ECU. I cant wiggle out the ECU box which is really limiting my leverag on zee big connector.
Thanks.
It's a 10mm nut in the center of the connector you need to undo that and the connector comes off as your undoing it
Neil
