Fitting 99 spec rear lights
Hopefully my (second hand) 99 spec rear lights will turn up in the next couple of days.
I was just wondering if anyone had any tips for fitting/sealing the lights to the rear.
Obviously I will have pulled most of the original tar off the car before instalation.
Should I use silicon or some other filler?
Thanks...
Thanks...
TBH I'd leave as much of the tar on as possible. The 99 lights should come with a layer of the stuff as well (depending on how they were sealed on the last vehicle) and you should end up with a nice even seal. If you still wanted to remove all of the old stuff, I believe some members have used silicone sealant successfully...
Nissan actually supply a roll of the tar substance for installing the 99 specs. Not sure how many people have actually received/used this however :confused:
Steve :)
'93 UK TT Manual
Steve :)
He's got second hand rear lights, so suggest that he won't have the 2 coils of tar supplied with items when new. Not sure if you can get the tar coils new from MJP. I'd ask Mike and see. Better off making a good job of it.
I cleaned mine all up and used the new tar coils when fitting mine. Centre panel needs no tar though.
Sorry, I did just see you knew that...durr..lol
LOL ;)
'93 UK TT Manual
Thanks...
when I bought my rear lights from Z-centre, Luke supplied a tube of black sealer which both sticks and seals the light cluster - might be worth giving him a ring!!! Be warned though, if you get it on your hands it's a pig to shift, tried white spirit, thinners, swarfega etc and still had the c**p on fingers for days!!! have fun!!!
Thanks guys,
I have had the old lights out once before so I know how horrible the tar is.
Luckily my new lights turned up today and they have sufficient tar on them so I don't need to worry about sealing them.
Moby - I used WD40 to get the tar off my hands last time, works a treat...
Don't forget to get some pics up!! I trust you're fitting a new center panel too.
Now, why didn't I think of that...................never mind, nice to know for next time!!
Brake fluid's good too...but there's the issue of it being just a 'little' carcinogenic! :rofl:
Actually I am! :cool:
I am not that fussed about the centre panel but the deal from Kirbz was too good to pass up...
Makes a difference though. Only looks like half a job otherwise.
Thanks guys,
You have to fit the centre panel ;) looks miles better
I tried to leave as much black crap on as possible :)
Post up pics when its done :cool:
I must admit, the centre panel does look much better than I expected, can't wait to fit it all.
Thanks for leaving all the black crap on, it will come in handy!
Of course I will get pics up ASAP.
Thanks again Kirbz...
