Engine Removal
I've removed everything gearbox, exhaust, mounting bolts but on lifting the engine raises a little then stops and the whole car lifts.
I've obviously forgotten something but I can't see what it is.
Anybody got any ideas.
Howard
I've always left the gearbox in. Just needed to swing the engine forward slightly to dis-engage it and go around the steering column. Its not going to lift the car but remember to unplug the oil pressure sender from the bottom of the engine. I can't think what it could be? is the drivers side turbo catching on the steering column?
Have you removed the steering nuckle?? it wont pass if you dont take it off??
Mike
