what mods for 400bhp ???
hey guys what mods would i need to acheive 400bhp would the internals have to be changed ??
  • Replies 30
  • Views 1.8k
ive been told internals will hold up to around 450bhp at the wheels, then pistons start breaking. 400bhp would require bigger injectors like nismo 555s and uprated fuel pump, probably stage 2 turbos, exhaust and induction mods, chipping and youd need an uprated clutch to handle the power. if moneys a bit tighter you can still take it quite far without changing injectors, thats the stage im at if u look at the spec on mine.
also worth adding though in my opinion if i could afford to have a forged rebuild i could as its always better to be running your engine at a lower bhp than its capable of as opposed to on the edge, as obviously no 2 are the same and yours could break at a lower bhp due to age/condition. im sure one of the mechanics can give u a bit more factual info than i have. what mods u got at the moment?
so i dont need a rebuild for 400bhp then ??? What kind of money im i looking at to get it there also whats the max boost you can run on standard internals ???
Are you after 400 at wheels or 400 at fly ?
(stock being 280 at fly, 230ish at wheels)
yes,if you want it to last
bigger rad, intercoolers, air filter,exhaust,down pipes,injectors,ecu, bigger tubs ( i doubt you will get enough puff out of T25's) and cams, wil get you 400bhp, but for all that work you may as well get the internals done. better safe than sorry
its the internals that cost the dosh at the moment the car has been chipped,air filter hks evc and an earthing kit from there what kind of money am i looking at including the rebuild to achieve 400bhp ??
lots for a fully rebuilt lump and all the trimmings 15-25,000
internals may cost but they are the heart of your engine
15-20K I would just get a V8 with tubs. Less money outlay for a MUCH larger BHP
I think Russ meant 1500 to 2500
One too many zeros me thinks.
no. 15k-20k for a high bhp vg30det inc. tubs and manifolds,ems,internals, etc.
400bhp at the fly can be achieved with the following mods....
APexi AVC-R and AFC-II
HKS chip
HKS induction kit
HKS plugs
Decat - and mongoose exhaust
Lightened under pulley
Courtesy of Mr.Reds dyno result.
if he did I spent WAY over the limit and I am only at 400
he only wants 400bhp!! at the f/w on a good engine you will achieve around this figure on a stock engine, tubs, injectors!
chip, boost increase, induction, exhaust. as basic mods.
lightweight f/wheel (if manual), underdrive pulley, decat as a bonus
uprated clutch if manual, gearbox if auto
im in canterbury if you want a chat bud :)
Personally I would do the internals first, make it bullit proof and then what ever you put on it, it should hold together
http://www.z1motorsports.com/product_info.php?cPath=1_6_14&products_id=1056
This is a start but you can spend a fortune on it, remember the more you stretch the elastic band the closer it is to snapping.
big boost needs less compression, weiscos seem a bit high.
good time to invest in upgrading the brakes first !
I gota say it. Zed stock brakes are a death trap. adding power only makes the car more deadly. Sory I dont care what anyone thinks about zeds stock brakes, they are shockingly poor for a car like this.
I've not looked too far into this as I don't have the money, what sort of compression do they give?
You should be able to get thicker head gaskets to compensate I would of thought.
And if the compression is a bit high then you wouldn't need the boost so high would you?
yeah would like to get in touch mate so we can have an in depth discussion about this an other things would be good to meet another zed owner in kent , obviously views are varied for 15-20 grand i could get alot more than 400bhp ,ryan at z-tech offered me 500bhp for 10 grand god knows what he could do for 15or 20 ,if your out there ryan or greg advice would be appreciated on this matter .
leave your no and we'll get in touch mine is 07969392714 look foward to talking with you
jim zx
jim zx
best bet is to pop in & see me at work as im there 24/7 it seems! Vikings Canterbury, Merc Garage in Sturry :)
sat mornings are the best - tho not this sat as its bank holiday weekend :hyper: :nana2: :duffer:
works no is 711112 - ask for Paul Crew
HKS chip
HKS induction kit
HKS plugs
Agree with the above.
400bhp can be achieved relativly easy on the zed with a good engine.
results here..
also the turbos have been rebuilt and have got 360 degree bearings in, run on optimax too...... 14psi boost
335hp at the wheels, they reckoned I could get a little more with a bit of playing around and the torque figure could be raised too, but i'm really happy so i won't bother.
and I love it !!!!!
another canterbury owner right here, be up for a mini meet when i get back in 3 weeks
yeah i be well up for that mate look forward to the "mini meet"
jim zx
