Hold button???
what is the proper function of the hold button ......... what was it put there to do coz ive been usin it as an economy button lol :confused:
  • Replies 38
  • Views 1.5k
hold button starts from second gear for slippy weather plus it dosnt allow kick down
you should be usin auto with overdrive on for economy
In the old days overdrive was generally for motorway/cruising, but as the light indicates ‘overdrive off’ this sort of implies that with the Z you can happy drive from standstill to whatever with overdrive on, is this the case? I guess that a user manual would be helpful.
Ye overdrive just adds the 4th gear if it needs to. You dont have to take it off to run around town, I never do. TBH I hardly even use 3rd. The only time I do is when I put the footdown. Cos on normal driving it goes, 1st, 2nd but when I change to 3rd it only stays in for 1 second or so then just drops into 45th. But that is driving like a granny though around town :D
why did they use overdrive instead of a 4 speed
Japanese over complicating things. I imagine it was town driving to save all the kickdowns from 4th to 3rd around low speeds
Also, at the time when the Z32 was first brought out the top of the range autoboxes capable of handling this kind of power were only 3 speeds. I think the latest Lexus LS will have a 8 speed autobox ... how technology progresses!
so how does overdrive work isn't it 4 gears
Its 3 gears and an overdrive. But unless there is some fancy answer. Yes it is just 4 gears
wheres the hold button?
Its tucked up inthe right hand corner of the gearshift panel look at the picture.
wow - nice interior - is just sprayed silver? want to do that to mine
ah ha sweet ill leave it alone den lol
It is good for when the engine is cold, stops the car from revving too much until warm...
It's also good for when the missus is driving. :x:
she can slam her foot down and I don't have to worry about her losing the back end on roundabouts etc.
You let her drive??? EEEK!!! How the hell can she cook and clean from the car? You need to make the chain shorter dude...lol
on my zed its always in overdrive coz if its not when it drops into 3rd from 2nd its like sitting in a jet and really accelerates!!!!! also its sounds like it changes 5 times? 1,2,3,4 then it drops revs again into a sort of fifth? also the hold button on mine just holds in it that particular gear and wont allow it to change at all?so if im in say 2nd it will indefinatly stay in 2nd til its turned off again?
hmmm i think im only gonna use it when its really wet or if fuel is minimum coz at the end of the day whats the point in havin such a car if its just ideling away all the time lol
that so called other gear is the torqe converter "locking up" at around 80km
is that bad? does that mean a new torque converter?
it means that the drive going in to the convertor is equalled to the drive commin out
yep perfect discription
its strange though coz i no a bit about normal gearboxs all be it on the truck side of things and over drive is the nxt gear on from direct drive...................
