handbrake on TT
Does the TT have this brake drum on the back for the handbrake, or does it go direct to each caliper.
Or is that n/a?
Im a bit confused :confused:
If not is it just a case of tightening the 10mm nut on the handbrake lever??
The handbrake goes to the drum bit unside the disc. There's a tightening bolt hole on the disc (with a little grommet covering it up). Have a look in the workshop manual and it'll show you.
the correst way to do it is slacken off the nut on the handbrake lever adjust the rear drums up tight then back them off 5 notches, then adjust nut up on the handbrake lever
It all makes sense now, lol.
Thanks.
Why the hell did they do it like that anyway...??
