As many of you may know, my bro-in-law has a black UK auto which I've been to a couple of meets in. The car has been off the road SORNed for a while and has recently been started up again.
Problem is there is now zero drive from the auto box in drive, reverse, 1st or 2nd gears :( The car was previously driving well and had no problems at all. We have followed the auto box self diagnostics but cannot get any flashing lights from the diag :(
Have checked the ATF fluid (hot and cold) and all looks good here as well.
Has anyone got any suggestions as to what we might try next?
CheerZ
Steve :)
'93 UK TT Manual
Run the engine until its all warms up, and then gently move the stick through the gears, see if it free's up.
If the car was driving OK before being parked up, and it has'nt lost any fluid, something's just stuck, and needs freeing up.
Have given it a go but no joy :( With engine running and handbrake on, there is no change in engine note or forward/backward momentum. Almost seems like something has become disconnected... :confused:
Steve :)
'93 UK TT Manual
...sounds like you need to get underneath it and check the electrical connections to the box. Alternatively is there a major fuse or solenoid switch that controls/protects the box? ...worth checking.
Good luck
Jack
Blocked fluid strainer or fluid pump.
Jeff TT
Thanks for the replies fellas!
Will take at look at those tomorrow Jeff :)
CheerZ
Steve :)
'93 UK TT Manual
CheerZ
Steve :)
Steve if you don't get it sorted I will be up that way next weekend so more than happy to take a look matey
  • 5 months later...
Steve....
PM Hexaking...aka Baz...
He might be able to help on this matter ;)
Only just come back to this and seen your reply bud :rolleyes: Many thanks!
'93 UK TT Manual
Finally got round to looking at this. Have dropped the ATF sump and removed the strainer. This is what is inside :(
Should the gauze come out completely? I've gathered from other posts that it should do. Also, there didn't seem to be any gasket around the ATF tray and I can't find the magnet that's supposed to be in there either :(
Any opinions appreciated! :cool:
CheerZ
Steve :)
'93 UK TT Manual
Clutch fibre, the strainer been blocked will cause lack of fluid pressure and no drive, equally the clutch fibre suggests other problems, it is feasable to clean the stariner flush and replace the fluid and you may get another 3 or 4 moths use out of the box, or on the other hand you will not, either way it is worth a go.
Daveman
Daveman
Thanks bud :bow:
'93 UK TT Manual
if you still got prob's with it bud i am going to break a J-spec TT,,at the end of this month,,so if you need a gearbox,,call me /pm ..
good luck bud ..
good luck bud ..
Hopefully it won't come to that, but thanks for letting me know in advance bud :bow:
Steve :)
'93 UK TT Manual
