low speed drivability after extensive mods
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
got moving after engine rebuild...
took 2 years, of which one was lost after engine meltdown on dyno and ensuing legal issues- to make a long story short, I had to pay for all damage and decided to rebuild with jun internals.Obviously ,I turned to other people for my actual setup.
Now I am driving with breaking-in mapping ( rpm cutoff at 6200,timing retarded)
555 cc nismo injectors(already installed before fatal dyno), rps flywheel, rps street max clutch.
further pentroof manifolds, td05-16g,twin intake without maf sensors(converting temp and pressure to voltage data),eprom swap on main ecu + unichip piggyback.
figures look promising with 480 flywheel hp and 599 Nm at 6000 rpm ,with power still climbing in perfectly straight line at 6000, so extrapolating at 7200 would give 500+hp...
at 0.85 bar!
But I have a drivability issue :
I must rev to 2000 rpm before rolling and adjust throttle to keep rpm at that
rpm or else the engine will stall
so smooth city driving is out for the moment as I must make the impression
of a motorbike racer on cocaine,revving like a maniac at each stoplight.
My new tuner says he would have favored standard 370cc injectors supplemented with 2 injectors ,one before each throttle body to avoid this problem.
(I know the mixture is still a bit too rich at low rpm but I doubt everything is attributable to this factor)
Is this typical for a light flywheel and/or big injector setup or am I just clumsy?
greetz
rik
