How much boost...
Right, so I've got the following mods on my car:
JWT ECU
Turbo Technics hybrid turbos
HKS rear exhaust section
Decatted centre pipes
Blitz induction kit
Boost adjustable via bleed valves under bonnet
My question is, how much boost should I be running on this setup. And can I adjust this myself fairly easily. If so, how?
Mike
If you still have stock injectors + intercoolers: 16psi (1.10bar) max
Anything above that is a bit dangerous, because the injectors max out at that point and you run the risk of running lean.
-Eric
15psi MAX
I wouldn't exceed this figure on a Stock fuel rig - infact i would keep it to 14 to be on the safe side ! - Yeah you can push higher but you increase the risk of damage to the internals and the turbos.
Z ya
Nico91TT
Dont be a Punk ...
