How do you change an oil fiter without using ramps?
Depending on how low your car is, and how high the kirbstones are round your way, you could park one side of the car up on the kird and that should give you enough room :)
I drive car onto couple of slats of wood (wide wood :p )
that gives me enough room to get my arm in.
I use a couple of bricks and a small triangle of wood to drive the wheel up onto them.
A jack and axle stand? :wack:;)
That's what I always did.. :D Seemed obvious to me.. ;)
That or a couple of bits of wood (four old kitchen cabinet doors :rofl: so very pikey)
loose wieght so u can slide right under lol
dont forget suck in just 2 be on the safe side :rofl:
jack axle stands and the spare wheel jammed under one of the front wheels.
Now that's paranoia for you :)
I drive up onto the yellow pages book - always knew it was good for something :)
I use one of them to stand on to get into my car LOL
Nah im not quite that short.
:rofl: :rofl: :rofl:
Get a small child to squeeze under the sill and have an oil bath :nana2: sorry
OEM jack on side sill
jack up on front subframe
axle stands either side for safety
job done
or drive on x2 planks of wood angled up on bricks does the trick
Just being devils advocate you understand, but...
If it's up on jacks, then it's not level. If it's not level, then don't you run the risk of not emptying it?
Is this a bad thing?
P.S. I've never done it on a zed yet, but I'm sure I'll just jack it up, but with a trolley jack so I can drop it again to get every drop out.
AAhhhh. :)
Now i know what he's on about - get the car level.
How about 2 sets of axle stands?
They are not expensive
TBH You cant get every drop of oil out of an engine it sits in places you wouldnt believe jacking up at the front is more than adequate :)
