personally id say 10/50 semi or fully synthetic mate , but i know everyone is different
Try the which oil (AAAARRRRGGGHHH) from yesterday -traders forum
I just bought 5 litres of Millers CFS 10w60 for my TT.
As recommended by an old wise man :D
Pete
60W is treacle - fine for Texas mid summer and track use but in UK in winter?
0-40W Fully synthetic. Wets those turbo bushes fast, no tappet noise on start up, perfect for winter.
and mines has starship mileage and original turbos
imho that is - now on year 5 of these trials
:D 10/50 or if you can get the stuff 10/60 which is much better for running the tubs, but like others have said it is down to personal choice and experience :D
Super market chain selling Mobile 1 synthetic 5w 50w, £17.98 for 4L
think ill go and do a bulk buy.
Same shop selling 1L for £11.98 !!!
Is it any good though
Have you used it before?
Asda is the store (seen it in the larger store not checked any of the locals, its a half price offer)
Havent used that grade before, not long bought the car and the previous owner ran it on mobil 1, 15w 50w. Others are using mobil 0w 40w on their cars but I know thats not recommended due to leakage problems etc, but the 5w should help that a bit. Dont take my word for that though i'm just a mechanic (or was) and not an oil boffin, but i'm certainly gonna try it!!
Is that new then?
I knew Mobil-1 came in 0w40 (which is as thick as water) and 15w50, but I never knew they did a 5w?
Richard :cool:
First time ive seen it as well, sure it says something like rally preformance or words to that effect ( planning on buying some tomorrow let you know then)
dont think the Z will handle the dirt tracks though :rolleyes:
Castrol RS 10/60 and here we go a fookingain LOL
AMEN :rofl:
Mazola 0W15
perfect for crispy chips every time.
if you prefer norvan soft ones then Lard 90W170
Ive been a fan of castrol rs10/60 but went for a thinner oil over winter as i get valvoline fully synth 5w/50 at a very good price.
These are the recommendations that I recieved:
Nissan, 300 ZX, 300 ZX Turbo (Z31), 1984-1990
Manufacturer: Nissan Motors Co., Ltd., Tokyo, Japan
Drive type: r.w.d.
Cilinder capacity: 2960 cc
Power output: 230 HP/169 kW at 5200 Rpm
Engine VG30ET
Petrol, 4-stroke, 6 cilinder, V, 4 valves/cil., Turbo, liquid cooled
Capacity: 4 liter
Filter capacity: 0.4 liter
Use: Normal
Change 5000 km/6 months
OEM recommendation
Above -20 API: SF SAE 15W-50
Above -20 API: SF SAE 10W-30
Above -20 API: SF SAE 10W-40
Above -20 API: SF SAE 10W-50
Below 15 API: SF SAE 5W-30
SAE 5W-30 oils are recommended for use in extremely cold weather conditions only.
Under severe operating conditions: change more frequently.
Capacity including oil filter and oil cooler.
Differential, rear, (4x2)
Capacity: 1.8 liter
Use: Normal
Check 10000 km/6 months
OEM recommendation
Below 40 API: GL-5 SAE 80W-90
Below 40 API: GL-5 SAE 75W-90
Below 30 API: GL-5 SAE 80W
Below 10 API: GL-5 SAE 75W
From -10 to 30 API: GL-5 SAE 85W
From 0 to 40 API: GL-5 SAE 90
Above 10 API: GL-5 SAE 140
Transaxle, manual
Manual
Capacity: 1.9 liter
Gears forward: 5
Gears reverse: 1
Use: Normal
OEM recommendation
year-round API: GL-4 SAE 80W-90
Transmission, automatic
Automatic
Capacity: 7 liter
Gears forward: 4
Gears reverse: 1
Use: Normal
OEM recommendation
year-round Dexron IIE -
Power steering
Capacity: 0.9 liter
Use: Normal
OEM recommendation
Hydraulic brakes system
Use: Normal
Change 40000 km/24 months
OEM recommendation
year-round Brake fluid, DOT 3 -
Hydraulic clutch system
Use: Normal
OEM recommendation
Cooling system
Capacity: 11 liter
Use: Normal
OEM recommendation
year-round Water with antifreeze (ethylene glycol base) -
Nissan, 300 ZX, 300 ZX Twin Turbo (Z32), 1990-1991
Drive type: r.w.d.
Power output: 282 HP/208 kW at 6400 Rpm
Engine VG30DETT
Capacity: 3.4 liter
Use: Normal
Change 10000 km/6 months
OEM recommendation
Above -20 API: SG SAE 10W-30
Above -20 API: SG SAE 10W-40
Above -20 API: SG SAE 10W-50
Above -20 API: SG SAE 15W-40
Above -20 API: SG SAE 15W-50
Below 15 API: SG SAE 5W-30
From -20 to 15 API: SG SAE 10W
Below -10 API: SG SAE 5W-20
Above -20 CCMC G4 SAE 10W-30
Above -20 CCMC G4 SAE 10W-40
Above -20 CCMC G4 SAE 10W-50
Above -20 CCMC G4 SAE 15W-40
Above -20 CCMC G4 SAE 15W-50
Below 15 CCMC G4 SAE 5W-30
From -20 to 15 CCMC G4 SAE 10W
Below -10 CCMC G4 SAE 5W-20
SAE 5W-20 is not recommended for sustainded high speed driving.
Under severe operating conditions: change every 5000 km or 3 months.
Capacity: 2.1 liter
Use: Normal
Check 40000 km/24 months
OEM recommendation
Automatic
Capacity: 8.7 liter
Gears forward: 4
Gears reverse: 1
Use: Normal
Check 20000 km/12 months
OEM recommendation
Transmission, manual
Manual
Capacity: 3.1 liter
Gears forward: 5
Gears reverse: 1
Use: Normal
OEM recommendation
year-round API: GL-4 SAE 75W-90
Power steering
Capacity: 1.3 liter
Use: Normal
OEM recommendation
Capacity of models with HICAS: 2 l. Top up only.
Hydraulic brakes/clutch system
Use: Normal
OEM recommendation
Grease points/nipples
Use: Normal
OEM recommendation
year-round Lithium base multipurpose grease NLGI No. 2
Cooling system
Capacity: 10 liter
Use: Normal
OEM recommendation
Hope this helps,
Simon
