I don't drive my Zed often these days (weekend car) and I'm on my third battery in as many years! Just wondered what the possible causes of battery discharge may be. If I jump start and drive the car, it will happily charge the battery and subequently starts ok. After a day or so in the garage however, it's flat again :(
Car has a recently fitted Toad i606 Alarm and average ICE setup. Is there anything I can test for/eliminate from the possible suspects?
CheerZ
Steve :)
'93 UK TT Manual
There is a constant current drain on your alarmget a trickle charger for your garage, or drive the b@stard more often :)
lol - what if I don't arm the alarm? ;)
Steve :)
'93 UK TT Manual
Steve :)
People will nick it ;)
take the battery out...
lol - Why didn't I think of that! :slap:
Steve :)
'93 UK TT Manual
i think most problems with dead batteries is alarms/immobilisers draining them
CheerZ
Steve :)
Steve,mine sits on the drive for a fortnight at times while I do bits and bobs but always[touching wood]starts first crack.It has a clifford fitted which is always armed-so this shouldn't be your problem, unless the alarm has an exceptionally high current drain/fault?also check ALL interior lights go off including the boot!
HTH.
Darren. ;)
i had this problem it was the alternater brushes stuck i had my alternater repaired it cost £70
Many thanks for the replies fellas!
Steve :)
'93 UK TT Manual
or you can get a small device which will keep your battery topped up (goes between a charger and your battery), not sure if that would affect your alarm though.
Vijay
