is my typing as bad as i think???
But the real question is
is the manual gearbox the same in the SWB
as the 2+2, and are the japs the same as the uk.
In short do they all fit and are the ratios the same???
many thanks
Allan
yes, Z32 manual gearboxes are internally the same for all models/flavours/countries.
The propshafts are different for NA/SWB/2+2
You can even use a NA manual box ..the only thing that's different on the NA box is the bellhousing, but this can be swapped with the bellhousing of a TT.
a SWB TT box will fit a 2+2 TT without any modifications.
Hi Allan,
If Lymon says so, then yes mate it is. He's one of the Z gurus :)
Vijay
