Upper inlet manifold removal...
I'm in the process of removing the upper inlet manifold - so far I have the coil packs out (and connectors numbered), balance tube off, throttle cables off, and some fuel & vac hoses off...
Question is; How are you supposed to get at the metal retaining clips on the injector connectors!? Damn they're hard to get to..
Az
Yes.. I know my back wheels *were* on backwards.. They're not now, 'k? ;)
Stage: Rather Ill
Just pull the cable (with force) and the connector should pop off.
You can wedge a screwdriver under the connector a little, if it doesn't want to pop off by itself.
-Eric
[This message has been edited by lymon (edited 01-10-2001).]
Ahhhh.. I thought you had to pop that little retaining bit of metal (the sort of square C shaped piece) out first (I did on the first connector, and it slid off really easily.. It's just that you can only get to that metal bit on No1 cylinder smile.gif)...
I'll just pull harder tomorrow wink.gif Shame it gets dark so early frown.gif I only got about an hour tops on the car, and I had to pop the batt off & onto charge in that time too (t'was a bit flat..)..
Cheers Eric.. BTW - I'll send some pics of my clocks just as soon as I can beg/borrow/steal a digicam - obviously can't take my car to the camera now! D'oh...
Az
Stage: Rather Ill
