Just a silver Z
After many years of thinking/ dreaming/ window shopping.. it happened 😇
This is officially my 300zx trip , 2+2 , auto .
136400km on the clock full Nissan Japan service history. Work vs xx wheels and a kakimoto cat back exhaust . And working AC.
Edited by HarryCy
Add details
  • Replies 30
  • Views 3.9k
  • A friend around is also a nice add on
  • Things move slower than expected now that I am back home.. updates.. Installed the gktec fan ( it’s loudish) Apexi filter is stalled Front strut bar installed Mono steering installed.. Xeon lights and
  • When I am back to Cyprus I will fit the rear speakers and decide if I will install an amplifier to the lot.. Further mods / future plans coming up: Nardi steering wheel Front tension ro
Me suspension installed/ instructions for the rear struts was non existence.. took it in and out 3 times both sides ended up reversing the oem rubber with the oem bump stop other wise the kw provided washer kept making nose due to empty space between strut and top mount 😤😤 it now feels amazing but so much money and no proper installation instructions..
suspension feel 9/10 instructions 4/10
Suspension tuning 7 /10
Due to annoyance not many pictures taken 1 video on YouTube did not showed the assembly of the rear struts …
That’s how the car sits at the moment
Also Japanese cheap workmanship .. rear Oem struts where blown and rubber spring spacer was used to stop the struts bottoming out lol
Lifted the front and the rear passager side blown and started leaking initially thought it was the fuel tank 😂
Front squick stopped and car is now solid 🤗
  • 3 months later...
updates..
Xeon lights and ballasts
Left to be done :
rear and front drift works camber adjustable arms..
Tires to install..
370z brakes to be installed
Rear strut bar
Manual gearbox conversion..
  • 5 weeks later...
So driftworks front camber arms installed and added abit so the wheels will come closer to the upper fenders..
tyres are also installed
Suspension is better adjusted .
Problems occurred.. fuel gauge decided to go for holidays and stayed there..
jobs to be done
need steering rack bushings and tie rod ends need replacing need to order the above..
Oil and oil filter needs changing possible 5w40
Bleed / replace the hydraulic fluid
Bleed/ replace the brake fluid.
