Boot and fuel flap release fault
The lever to release the fuel flap and open the boot has ceased to work properly....
I can no longer release the fuel flap, nor will the boot shut properly - any ideas?
Could the cable have stretched or got stuck on something - and how easy do you reckon it is to fix. I do have a spare brand new cable if need be, but I have my MOT on Monday and the tester will need to access the fuel cap 😞
I guess I could pre-open the flap by pulling the cable lever behind the near side tail light - luckily I don't need petrol just yet LOL!!
If you undo the centre boot trim, the one directly behind the rear panel for the reverse lights, can you pull on the cable to see if it's stretched or caught?
It should run though a plastic 'runner/spacer' to support the cable and might have just popped out,
I am pleased to report that I have fixed the issue.....
The little plastic fastener had broken at the release lever. Luckily I had a brand new Nissan part sitting in my garage 😉
  • 2 months later...
That happened on mine as well.  Odly the boot would open but not the fuel flap.  Took me ages as i started at the wrong end 🤦‍♂️
Membership No 0780
INSURANCE GOOFA
  • 6 months later...
Typical, finally got my car back, went to fill up and the cable snapped!  Anyone for a good spare before I reach out to the usual suspects
Also need a better battery cable 👍
When this happened to me I used a credit Card to open the the fuel flap. Slid behind the catch a treat
Hi Tony, got it open with a trim tool, (careful with the new paint!)
Filled it up only to find a leaking tank. 3 pinholes to weld  up, replacement cable on its way . . .
