I am not too pleased with the garage that has just failed my Z not once but twice!
23 JAN 1st Fail Front track rod ends / rear offside HICAS ball joint
With 3 advisories - Drivers seat belt anchorage/ rear nearside HICAS ball joint/ offside rear inner ball joint
All nearside & offside HICAS ball joints & front track rod ends changed.
Back for MOT not a re-test
30 MAR 2nd Fail! Parking brake efficiency below requirement!
No mention of this in the last MOT advisories otherwise I could have got it done! They offered to do it, in 10 days time.
Same tester Same garage that has done my past 7 MOTs
Peed Off!
Sorry rant over
That is annoying!! I feel for you. Where are you based? If you're going for a full new MOT then time to look into an alternative testing station?
It seems suspicious that they can only do the work after 10 days, which just happens to be when the re-test window would be over...
