5 hours ago, Joely P said:
Nope, just my internet browser. It would probably be easier as an app though, even if it just opened the browser, in the app!
Nailed it a web app. My work has a web based client (as well as a fully fledged separate app) and you can access that via a web app. Makes the user experience so much better.
Albeit on Apple IOS you can hit the button at the bottom when in the browser and select ‘add to home screen’ which will give you an app button on your phone to portal you through to the webpage. Not sure of the performance on Android.
Tapa talk is a hateful piece of software. The idea behind it 10 years ago was great, but it failed to progress and each update made things worse.
It is rather frustrating that every so often when logging in here I have to confirm yet again I want to continue on Chrome (android 13) and not use TapaTalk
This works ok but as it just shortcuts to Safari, after a few days of clicking the app icon, it means we’ll have several tabs of the same website open!
Exactly, I get this too and hence the reason to see what peoples views are.
I just want to ditch it as its no longer needed.
