Underbody and all that goes with it.
Hi Guys & Girls,
The Porsche is up and running very nicely, so onto the 300.
I am looking to refurb the front and rear subframes, the whole underside, brake lines, PS lines & Fuel lines. Big Job.
Started by removing the rear bumper, looks like it has never been off before, then draining the petrol (still in the process).
Took some underside pictures of the task in hand, it’s not bad mostly surface rust. I will be cutting all rust out and welding it my
self, if I can build a complex Porsche engine and it hasn’t exploded after 300 miles, anything is worth a try.
E7BB6F80-0403-41B3-B1F9-D15070B0B44C.jpeg.d6826d5277c603ab22e5da3c8cb62d39.jpeg4B2DCEAD-0062-46C5-B2BD-ADDB2A3F4F3A.jpeg.cd9af7ab51b8a6fff759bb4fa7511d08.jpeg
BE2B1788-A506-41C3-BF41-9020F9D20CC9.jpeg.7d59b6ae033a9917aa7d5e1ca83c25e9.jpeg5D03E7EA-761A-4564-BB39-CCF34A4CE1E2.jpeg.0d0a294c21a011d109f653f758205ab9.jpegF5F9133F-106C-485B-913C-3700EFCF0440.jpeg.83ab7f725cf72b55b277125fcf099201.jpeg
3E0871E1-CA8A-4089-9748-2599CA5DCFCC.jpeg.3005c8fc4120c8fe180a571ee22e9a45.jpegAFBD9AE8-143C-4AC9-BD56-B7E51759E470.jpeg.7e0f1ac9b9a73d4db7bf16b948f98f25.jpeg44B2BE3E-3B10-48DF-8D43-DBDF31A11EF6.jpeg.ac1efc906b45c15f1859b13f677a1014.jpeg7EF10535-28CE-4CE4-AA2F-DA8BA54FF5D7.jpeg.1a570a49704307fd3fc1bf80c4ce8bed.jpeg23B614FB-6FEB-437A-AF61-FEAE2F5DBEEA.jpeg.a1d99d20a3300224fc69137047ca3c26.jpegD382ED25-5839-455B-9CFC-20D8028B4B6A.jpeg.5f569fdd158c677f5205f4bf2220bb4c.jpeg4BE48671-F38E-46A6-99B3-994CE3ADF906.jpeg.d3ed6ab9bde9d98059de6edf6afe093e.jpegD55D7420-0E24-445F-A763-86EC90746575.jpeg.64c7f029c1de2107a5845a6a73cc02b6.jpeg
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
  • Replies 97
  • Views 10.7k
  • I have started on stripping out the subframe today, most nuts have been loosened but the half shaft bolts will need some heat persuasion tomorrow.
  • Today I removed the acid etch primer was an old can, and purchased some, Rust-Oleum Hard Hat Anti-Rust Corrosion Primer 218. The laser had it off in seconds. I have also found out a few passes with th
Hi not been able to do much last few months but got my petrol tank back from being powder coated.
Diff looks good I’m only going to replace the drive oil seals + new fill, drain plugs & vent pipe.
IMG_5840.jpeg.186d277abdd0cef269bdcea14ea77785.jpegIMG_5841.jpeg.69cbb2893d0ddf2c51fee2dcf5ac3fc1.jpegIMG_5849.jpeg.837ccb68e2701760cf64954c6965cbcc.jpeg
Edited by Bones28
2004 BMW Z4 30i
2004 BMW Z4 30i
I managed to get the drivers seat out and carpet up a bit to see where the floor meets the sill,
It was not as bad as I expected.
Section by door hinge.
IMG_5854.jpeg.90cf443fb2c9909718dd96f02f017f37.jpegIMG_5855.jpeg.f52e479f62a6a2c3ba007261f65037b5.jpeg
front fight corner of floor pan.
Rear floor before seam sealer removed, and after.
IMG_5858.jpeg.d5ccfaad882ed0ec3ee87342ecca23ed.jpegIMG_5859.jpeg.223da8703d6232c6bb84218d8e7539cc.jpeg
Edited by Bones28
2004 BMW Z4 30i
  • 6 months later...
This Easter I have been stripping the front end I’m hoping to drop the engine, gearbox and suspension out from underneath. Then I’m planning on buying a rotisserie to make things easier to work on the underneath.
2004 BMW Z4 30i
  • 1 month later...
Hi been a little while spent most of last month in the US seeing family,
Went to a car show.
IMG_6775.jpegIMG_6771.jpegIMG_6772.jpegIMG_6768.jpegIMG_6763.jpegIMG_6756.jpegIMG_6751.jpegIMG_6749.jpeg
2004 BMW Z4 30i
2004 BMW Z4 30i
Camping
2004 BMW Z4 30i
Well back in the real world, stripping the car. When I took it off the road I gave it a last blast down the motorway and the double nuts on the exhaust down pipes cane lose some fell off not so bad was worried because of the noise, also I had coolant pouring out of the front somewhere. Looks to be above the water pump in the valley.
2004 BMW Z4 30i
I learnt a hard lesson lesson last time I took the engine out, the crankshaft cog was seized and had to be cut off, but before that I tried to pry it off and a hairline crack was made in the oil pump, this was only found once the engine was put back In and started, so be very carefully cut it rather than pry it off, I put some copper slip on the shaft and this time it slid off with very little pressure.
Edited by Bones28
2004 BMW Z4 30i
For all you picture fans.
2004 BMW Z4 30i
Not the easiest way but worked for me.
IMG_7286.jpegIMG_7287.jpegIMG_7288.jpegC96E35EA-B86B-47B2-ACDC-19F0DB8D4E30.jpegIMG_7294.jpegIMG_7293.jpeg
2004 BMW Z4 30i
I managed on my own to get the engine on a stand and lowered the car back down, not easy.
2004 BMW Z4 30i
Got most of the engine stripped, I wanted to see the bearing shells car has done 97,000 klm and just want to get away with new standard ones.
Will remove more tomorrow.
The twin turbo engine is a lot of work to disassemble, so many parts have to come off in a certain order, I have new manifolds and downpipes so a full strip down is required.
IMG_7362.jpegIMG_7363.jpegIMG_7364.jpegIMG_7365.jpegIMG_7366.jpegIMG_7367.jpegIMG_7368.jpegIMG_7369.jpegIMG_7370.jpegIMG_7371.jpeg
2004 BMW Z4 30i
Stripped moat of the engine bearings are worn but perfect for just changing so glad I’m doing it now rather than waiting till it was to late.
IMG_7381.jpegIMG_7383.jpegIMG_7384.jpegIMG_7383.jpegIMG_7391.jpegIMG_7393.jpegIMG_7392.jpegIMG_7393.jpegIMG_7394.jpegIMG_7397.jpegIMG_7398.jpegIMG_7399.jpeg
2004 BMW Z4 30i
Started the Laser up for the first time this year and got a very quick clean of the cylinder head before it started raining.
2004 BMW Z4 30i
Hours of cleaning in 5 minsIMG_7425.jpegIMG_7424.jpegIMG_7423.jpegIMG_7422.jpegIMG_7421.jpegIMG_7420.jpeg
2004 BMW Z4 30i
  • 7 months later...
Parts freshly back from powder coating
IMG_1224.jpegIMG_1225.jpegIMG_1226.jpegIMG_1227.jpegIMG_1228.jpegIMG_1229.jpegIMG_1230.jpegIMG_1231.jpegIMG_1232.jpegIMG_1233.jpeg
2004 BMW Z4 30i
IMG_1236.jpegIMG_1237.jpegIMG_1238.jpegIMG_1240.jpegIMG_1241.jpegIMG_1243.jpegIMG_1242.jpegIMG_1234.jpegIMG_1235.jpeg
Edited by Bones28
2004 BMW Z4 30i
  • 1 month later...
Built the first part of my rotisserie.
2004 BMW Z4 30i
