Z1 Accordion Pipes
Got a set of these pipes which the ports going to the cam covers have came loose.
i've tried various types of rubber glue but nothing i try seems to fix them in position and they seem to be able to move about.
The adaptors are both alluminium so any advice on what can stick them together.
Have a look at Sikaflex Lee, it may adhere to silicone.
How about trying that UV activated adhesive that's supposed to be able to glue anything ?
Sent from my SM-N920C using Tapatalk
Go and buy a barb fitting with a threaded Male end. Three nuts and a washer. It’s gonna be fiddly but that’s your best bet.
Assuming that the silicon nipples have just stretched try reversing the inserts and see it that holds them firmly in place.
If that works I will machine new ones for you with a larger diameter (to be determined) part that goes into the nipple.
