Catalytic converter light
Hello guys,today i sarted the car in 6 months and every thing was fine until i seen a light appear on the dash,looks like Catalytic converter light,Did anyone else have this problem?search?q=300zx+catalytic+converter+light&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjzwPiw-qzjAhVXRxUIHS4bC_4Q_AUIECgB&biw=1499&bih=873#imgrc=OnIovfnYblKERM:
Like this
https://ibb.co/NSL3gWM
Like this
Also just to mention i ajusted the TPS before starting the car could this be causing it??
I found this
http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.12
It's just the cat overheat light, they fail (the probes). Most people have either removed the bulb or disconnected it.
Most common issue is after an exhaust swap the exhaust overheat sensor cables are snipped out and later short out bringing the light on, that said is you had any kind of a misfire and neat petrol was going down the cat, it would light up in there and bring the warning light on.
Jeff
