Help Identify These Rubber Seals ... Please !!!!
found these under my parts box and i nearly cried , im guessing the orange 1 is a for an engine plug sensor and the black 1 no idea, is there a seal between the driveshaft and gearbox any help much appreciated, before i start pulling the car apart again .... :censored:
60340901_10155969946041644_1088756501385838592_n.jpg?_nc_cat=107&_nc_ht=scontent-lhr3-1.xx&oh=96dd98b265c74cedb05818aea4ac5e9b&oe=5D74B1F0
Top : i recognise this but not sure where from, is it plastic or metal ?, and is it the same looking both sides ?
Bottom : Coil Pack connector
cheers jaikai, the top 1 is rubber and is about the size of an oil filter so racking my brain on wot ive had off the car and was thinking oil seal between gearbox and driveshaft maybe the little tunnel that the gearbox has and the driveshaft fits into, theres not much that size that ive took apart, engine was out not dismantled in anyway apart from turbo's removed so drivehsaft out and all vac pipes electrical connections etc removed and gearbox.
Whats the actual diameter of it ?
Both insde and outside That should give us a clue
The big one looks like an oil filter seal. I can't recall ever seeing anything like that otherwise. The little raised bits would grip the pressing in the filter, if it had been fitted without oil being wiped on the seal, it could have stuck to the oil tree when then filter was removed and then fallen off.
if its an oil filter seal i dont ever remeber it being there, it is about that size thou and it 65mm in size with weird
60296722_10155973437651644_278954990549073920_o.jpg?_nc_cat=106&_nc_ht=scontent-lhr3-1.xx&oh=13dffa89d3c9534483af189527841ace&oe=5D9DB4CB
60211556_10155973437391644_7628357002871177216_n.jpg?_nc_cat=109&_nc_ht=scontent-lhr3-1.xx&oh=68113568496336f0f4daaacc50c00b4c&oe=5D5EEB80
Don't think its from the oil filter Martin as the filter seal is not flat like that one.
This can depend on the filter manufacturer.
if you look carefully you can see the seal is quite thick, i would say it's come off the old oil filter.
