Anyone have a horn relay, padded envelope and a PayPal address please
Have a look bud. I have a feeling that relay isn’t a fancy pants Nissan con part but a generic Bosch relay available from your local motor factor.
Yeah did try locally but no one has 3pin 15amp.
Sent from my SM-N920C using Tapatalk
3 pin... weird.
This oneba21086fbad33c91de96aa2ccaf2d008.jpgaabe28a9ebef114e5aa1fc0799dc9f91.jpg
Just have to ask as it not often they fail, are you sure you need a replacement one? have you tried linking it out on the base to see if the horn works? it is really common fault to loose the cable from the steering wheel horn push to the relay, rewired scores of them over the years.
Jeff
Aha! I'll open it up and have a look first then, thanks jeff
Jeff
Cables chased and horn working fine again. Problem was a loose earth. Thanks
