Alarm/immobilized help - I'm stuck
Currently sat outside a sports hall in the dark, so any help would be greatly appreciated.
The car was working and driving fine. Pulled up and got out. Car wouldn't lock/arm with the fob. So just locked with the key. Anyway, now I've come out, the fob still ain't working and the immobilized is on. So I can't start.
There's normally an led on in the car, and that's not on or flashing at all so I'm guessing it's a wiring issue. Anyone know how to bypass an immobilized or have any idea where it might be wired to if it uses a fuse?
Many thanks,
Lee
Membership No 0780
INSURANCE GOOFA
That happens to me with a flat battery, and then the logic gets itself wrong
I get the jump.leads on lock the car with the fob unlock it and then the led is on, usual start from there
Many thanks,
Lee
Lee have you tried replacing the fob battery or taking it out and and giving it a rub in-between your hands and reinserting it otherwise unscrew your fob backing then try it with a bit of pressure as the connection within the fob can wear over long periods and when pressing it, it doesn't touch if that makes any sense. That's all I can suggest buddy, good luck with it.
Sent from my WAS-LX1A using Tapatalk
Thanks all. I managed to get the car started with an emergency code once neen found it. The LED isn't working at all, so I think it's something wiring rather than the fob. Plus it had worked perfect all day
Membership No 0780
INSURANCE GOOFA
Well done getting it going again. :thumbup:
Bit of a highjack here but how easy are after market alarm/immobilisers to remove? My car has a Toad system that is showing its age, the “total closure” box was failing so I removed this but now I want to remove the whole system before it fails.
Hi Lee,
What type of alarm are you running and who fitted it ?
Glad you have it working again, I've just bought a new toad system and I think I will be doing a writeup on how to fit it properly.
Although for obvious reasons I think it will be posted in the subbed area.
Really surprised that a toad alarm is failing although the closure box isn't part of the toad alarm.
I've seen a lot of alarms over the years and I would say that the toad AI606 is best alarm for the zed.
If its installed correctly there's nothing that could ever fail apart from a battery running out.
Strangely enough I've just ordered a new one along with new sensors for my current zed project.
Which Toad system have you got?
I don’t know mate, I’ve not got any paper work with it.
The alarm and immobiliser seem fine (other than only having one remote) but the total closure box was falling appart. In fairness it might have been messed about with after the initial install due to a respray but can’t confirm.
Edited by Chris300
Hi Lee,
Mine is a Simga M30. From all the searched I do, it's an alarm that Subaru used quite heavily so struggling to find much else. It was fitted in like 2001 though
Membership No 0780
INSURANCE GOOFA
If it is a Toad AI606 then the specified immobilisation circuits (usually fuel and starter motor) are described
in the installation guide:
Ai606_Install.pdf
Trace the black immobilisation wires to where the circuits were cut and rejoin the wires back together.
Edited by AndrewG
Spelling!
[ATTACH]114175[/ATTACH]
That's the sort of manual I've been looking for, for mine but I can't find one anywhere
Membership No 0780
INSURANCE GOOFA
Just an update. Been away but when I got back I tried to look around for a loose connection believing it must be that. Turned out to be a bad earth on a bolt.
All working again now
Membership No 0780
INSURANCE GOOFA
