My Black SWB TT build
I thought i would start a thread to display the progress on my zed. Been a fair few years in the making with extensive list of work ive carried out and i thought it may be of use to others for ideas.
Link to album here may work
https://beta.photobucket.com/u/Gonzo12c/a/af3db6f5-a9c6-4621-9630-f2e688c0d97a
Here is the spec:
Exterior
new windscreen and windscreen trims
New targa trims complete
Rear Fog/Reverse LED conversion plus red lit `300zx'
Angel ring sidelights in headlights
Genuine 99 spec rear lights all 3
Clear rear bumper markers
Rear and side windows tinted
Genuine Wings West front bumper
Genuine Bomex side skirts
Genuine Bomex rear apron
Front wings smoothed and indicators relocated to wing mirrors
Aerial deleted and smoothed
Rear wiper deleted and smoothed
Rear over fenders fitted blended in
Carbon fibre scuttle panels with gold mesh
Carbon fibre rear diffuser
Gold Z badge on headlight panel
New door seals (to fit)
Interior
Full interior retrim in off white leather with blue stitching and 300zx logo and series 2 arm rests same leather and stitching all done by Mondo
Both seats are electric and aftermarket heated
NISMO carbon gear stick
Chrome door handles
Noble M12 Momo steering wheel
Momo handbrake handle in blue alcantara
Blue Illuminated stainless steel kick trims
18mm MDF boot floor
Full lock set with original 3 keys (to fit)
In-Car Entertainment
Pioneer 8in screen headunit
JVC 6 x 4 rear speakers
Pioneer front speakers
15” Infinity sub and Magnat amp
Engine Performance
Nistune ECU
NGK heat range 8 spark plugs
AEM adjustable FPR
Apexi turbo timer
Apexi twin stainless steel backboxes 2.5"
Japspeed decat pipes 2.5"
HKS 2530 turbos and 5 bolt downpipes
NISMO 740 injectors series 2 fuel rail
Ashspec massive V3 SMIC
Ashspec 2.5 inch IC piping
Ashspec planar intake pipes
HKS SSQV dump valves
Twin JWT 350z filters on twin MAF`s with Selin translator
New wiring specialties harness
series 2 PTU
Koyo radiator
Braided turbo oil feed pipes
one piece stainless steel clutch hose
RPS max street clutch and lightened flywheel
Mocal oil cooler
HKS EVC 5 BC
Z1 58mm throttle bodies
New timing gear idlers and tensioner
Unorthodox complete pulley set
Optima red performance battery
AEM boost gauge
AEM AFRs
AEM coolant gauge (to fit)
GKTech fan (to fit)
Engine bay dress up
Stainless steel throttle cover (to fit)
Custom painted throttle cover
NISMO oil cap
Powertrix CF slam panels
Fuse box relocated
Z1 blue heater hoses
Roose Motorsport blue engine bay air hoses
Z1 radiatior hard pipe kit in blue
AMS clear timing belt covers
Custom-Zed gas bonnet strut
Chrome PS pot relocated and PS lines modified
Gold battery terminals battery relocated to the boot and custom power cables
Inner wings tidied up and smoothed
Blue powder coated coolant pipes, plenum, CAS bracket
Gold powder coated balance pipe and camshaft end plates
Chrome CAS
carbon canister deleted
AIVs deleted
Plenum coolant bypass
EGR deleted
NA PS pump, HICAS and all pipes deleted to the rear
Custom-Zed stainless steel bolts and coloured washes throughout
Suspension
Meister R coilovers
Powertrix FUCAs
Powertrix tension arms
Powertrix rear toe arms
Powertrix rear connecting rods
Powertrix rear upper arms
NA rear subframe (no HICAS and shorter diff ratio)
Nissan motorsport front and rear strut braces
Wheels and running gear
R33 Skyline GTR front and rear Brembo calipers and discs
18" Mania alloys
Zedworld one piece prop
Short shift kit job
Winner of best SWB Zed 2019
Edited by Gonzo12c
  • Replies 27
  • Views 4.1k
  • A little update as I’ve always got loads going on and plans for the Zed. Wheel colour this time. I’ve been watching some successes using liquid wrap which you can spray on and then peel off if not hap
  • Some new shoes fitted on the rear today Federal FZ-201. Got Racelogic traction control going on as well which are getting rare although another one has just popped up on eBay. Sent from my iPhone
  • Installed the Racelogic today however didn’t get chance to calibrate due to wet weather. Looking forward to getting it fully working and have launch control on the Nistune new firmware. Sent from m
This was the first Z32 interior I ever did. It's crazy that it's only recently seen the light of day for the first time!
All good things take time and i had alot of custom work to do in the end. 3 shows done now this year though.
  • 1 year later...
I've been busy accumulating more parts and another shipment coming in from CZP.
New door seals to fit along with a few other OEM upgrades to the door lock barrels.
Shiny parts to fit include stainless throttle cover and GKTech fan.
Dash will be out this winter as I have an excellent condition one to go in along with a centre gauge cluster with the 2 AEM AFRs and coolant gauge. Looking to pick up some new wheels so I can get some wide semi slick tyres on the rear before going in for another tune since I was losing traction before.
Having been spoiler less for a while now I'm looking at options to add something that is low similar to a 99 spec.
A lot of nice upgrades Gonzo :thumbup1: Looking forward to some nice pics of this prize winning black SWB.
Ah quite right you are and if this link works then it should show the most recent pictures the the garage.
https://www.300zx.co.uk/forums/showthread.php?190739-Pearl-black-SWB-TT-zed-1991-Nissan-300zx-Manual-SWB-TT
A few new parts to fit complete with new door seals.
Edited by Gonzo12c
Awesome Zed, Marty.... And a well deserved win :thumbup:
Pulled my zed out of hibernation today. First job was to fit the new AEM FPR and set the base idle. Now running sweet.
Next is time to play to play about with my fuel map to get to a good base map since it’s a long way from standard.
  • 3 weeks later...
An update in pictures on my Zed build. Dash is out for the new one to go in, engine bay slimmed down and even more tucking done along with clutch vacuum tank delete. A few extra bits
going in with some very custom work going on in the near future.
The bare engine bay is what I’m going after and I’m sure we have seen plenty done on NA zeds that’s the easy part a bit more difficult on a TT.
More deletes going on in the engine bay and more parts on order from the US.
If you carry on at this rate Marty, the engine itself will be next to go !!!!
Hmmm you’re right RB lump would look better.
Had some kit lying around so just installing it while the dash is out.
Offering up the new master cylinder for a booster delete.
My tucked engine bay is nearing completion. Going to move my fuel valve up and in for a tidier display. Need to find a fan shroud which I’ll shave and modify.
I’ve seen plenty of tucked bays on the NA but not many at all on TT.
Few questions Marty.
So your now going to have non servo assisted brakes? Have you retained the ABS?
Are you still running stock fuel pressure? If so what’s the reason for the aftermarket FPR?
Regarding the brakes I’ve got testing to do on this so I will confirm all once complete.
With the AEM FPR I am on standard pressure however due to being on Nismo 740cc I am on an AEM fuel pump and a direct feed with this to feed constant fuel. The pump has its own built in relief valve and with this set up and the aftermarket FPR I can ensure that fuel pressure and delivery remains constant and will not lapse on high demand situations.
This therefore cuts out the fuel pump controller.
Also the stock set up will only take you so far in terms of BHP.
Knocked up a shelf today to replace the stock one so that I have somewhere to mount my bottles. I wanted the ability to turn them on from the drivers seat so this is ideal. 9ccc274242fedacff2b8094391653f39.jpg
I always find with the bypass on the ecu done and full voltage at the pump the cars have a tendency in being over rich at idle,The adjustable reg is a good way of controlling this.That is the main reason i use adjustable set ups.The stock regulators are pretty good otherwise for decent power levels.
  • 5 months later...
A little update as I’ve always got loads going on and plans for the Zed. Wheel colour this time. I’ve been watching some successes using liquid wrap which you can spray on and then peel off if not happy. Not a fan of vinyl wrap due to so many jobs looking incomplete and poor.
Liquid wrap is basically plasti dip made better in that you can get pro get sprayed with a gun that can be sanded and polished after you apply the topcoat or follow the trend of 10 years ago and stay matte.
Started experimenting with it and half way through my wheels now as my end colour scheme will finish with a shade of gold wheels. I’ve got 11J Cosmis on the rear that are practically brand new so easy enough to clean up for the job.
I’ve used 3 coats of black matte as the prime and then one coat of the stealth gold which being called stealth think pearl as it will give off a different depth of colour at different angles. I’m going to give a second light coat of gold on this before the top gloss coat. Being liquid wrap it isn’t prone to runs as much as paint is and is a lot more user friendly plus if you don’t like it you just peel it off [emoji1]
I plan on doing the whole car in the end with another colour and will leave it to the final pictures. The company I use also provide training courses which I will be booking on.
