Which Oil Filter - 300zxTT
Hi Guys
What engine oil filters are you using as Nissan OEM only seems available in US?
Martin
OEM filters are plentiful in the UK. They fitted a number of cars and generally your Nissan dealer should have stock. Not sure why you're having difficulty in finding them, having said that, the last 3 or 4 filters I've had have been WIX.
I use either OEM or WIX filters. Not tried the K&N ones, but aware the quality is good.
Avoid FRAM and non branded oil filters like the plague. They contain low quality filter media and are of cheap construction.
Thanks for the quick replies - Searched for Nissan filter # 15208-55Y00 which may have been replaced by #15208-55Y0A but no luck from Google! Will phone Nissan Dealer tomorrow.
Martin
Cannot understand you can't get OEM ?
I have A2508H890C oil filter & 1102601M02 washer drain.
Martin
I think that's the old part number. That filter went NLA years and years ago. The one that Nissan supply now doesn't have the non return valve in it. The WIX filter does contain the non return valve and I believe so does the K&N. They're all good though.
Surprised if these are not available at any Nissan dealers as they fit many modern Nissan`s as well as the group of older cars on the label.
Edited by JeffTT
