Im doing timing belt sarveic soon so my tuner ask me to adjust my jun came gears 2+ intake only is that coz a rough idle
Sent from my G8142 using Tapatalk
American Apache?:red_indian::biggrin:
No offence intended.
Im going to adjust my came gears 2 degree is that affecty my idle stock cars idont need your comments thanks
[emoji19] helpe or stop talking
Oi, less of the attitude. If you can't be bothered to write a legible sentence......
Your idle is controlled by both your idle control valve and your TPS. Make sure those are adjusted. You shouldn't need to adjust the timing gear for idle.
Jwt 272 r5 camshafts jun came gears adjusting 2 degree will change the engine timing iwant to know the idle is stay the same
"Your tuner" asked "you" to adjust "your cam gears". Time to pay more, or find a new tuner pal.
He says only intake came gears 2 degree advice [emoji28] bigger turbos and built engine
What exactly are you confused about? If you’ve got the adjustable cams you need to move them to achieve an advance or retardation of the cam. There will be graduations on the gear.
Personally I’d leave the upper cam covers off set it to zero and let your tuner set the timing during the process, guessing you want 2 degrees is useless.
Edited by Stephen
Its not about how to do it its after its done the idle will be the same?
I don’t know, I’ve not done it to a VG. The engine I did it too had a wild cam profile and idled like a bag of crap. But from what I understand your cams aren’t that wild. I wouldn’t of thought idle stability will be that much effected, if you care about that are you doing the right modification?
I don’t really understand what you want.
He he eh it's ok thanks any ways it's seems nobody change his came gears to adjustable ones thanks man im going to ask another tuner
Cams are a relatively uncommon mod on these engines, generally people will just use more boost and encourage other external breathing mods. Maybe ported heads. Larger valves, extra displacement and cams are generally not included in most peoples builds as you can achieve strong power without resorting to such expense. It’s not like tuning an NA.
All your doing by advancing just the intake cam is adjusting the valve overlap.
Advancing the intake valve opening will increase the valve overlap which in turn make idle worse, not better.
Find yourself a new tuner, he’s talking pish
Edited by nickz32
