My daughter calls it Toothless the Dragon: My ‘95 TT Z
As with most projects and rebuilds, they all start in the same place, mine was no different. However, this isn’t truely the start of my forever ongoing Z project. I’ve owned this car (my second Z) since 2008 when I purchased it from a former member. For the first 5 or 6 years I did the usual mods with suspension parts and basic bolt ons. For reasons unknown, whilst running stock boost, piston 5 cracked a ring land during a track day at Castle Coombe. A forged build and a remap later all was well until a sunny October’s day 2013 at Bruntingthorpe killed that engine with what at the time was a suspected head gasket failure at 181mph..... And this is where I shall start my journal.
The Z was stored off the road from Oct 2013 until March 2015. I’d had a major knee operation at the beginning of 2015 which meant I was going to be off work for 6 months. I’d saved up enough to start thinking about a parts list to rebuild her and frankly, after a couple of months of staring at the same 4 walls, I was going stir crazy! I employed the help of a good friend and decided to pull the engine and see what was what.... just a head gasket my arse!
March 2015
Problem 1: It turns out stainless steel, exhaust wraps and condensation don’t mix well
Before I’d even got the engine out, a new set of downpipes was added to this list. These AMS items were only 2 years old, so I was far from impressed! I contacted the retailer and after a bit of tooing and froing I secured myself a set of replacements for free... how long they will last, only time will tell!
  • Replies 674
  • Views 103.9k
  • Hey all.   well I’m happy to say my engine saga is now pretty much behind me and I’m free to move on with my car!   So, what does the future hold…. Well I’ve pretty much got to start
  • After a bit of testing with various polishes and pads, we found that the Lake Country wool pads with Scholl Concepts S3+ followed by S20 Black on a meguairs polishing pad, then finished with S30+ on a
  • Over the last few months, a friend of mine and I have been undertaking the most thorough detailing work I’ve ever undertaken. Just over 70 hours of work have gone into my car, from 2500 and 3000g
Engine dynos FTW! Nice work well done [emoji1417]. What’s the target of your build - track/drift/fast road?
1 hour ago, naz27 said:
Engine dynos FTW! Nice work well done emoji1417.png. What’s the target of your build - track/drift/fast road?
It’s just a fast road build, however I wanted an understressed engine. The engine is built for 1000hp and 8500rpm, but I’ll only be running at 60-70%ish of that power and a lower rpm, so should enable many miles of thrashing without any worries about the components being close to their operational limits
2 hours ago, Gaz 300 said:
Haven't a clue what all that means Nick but you know what your doing so good luck mate. ?
It just continues my ethos of having the best quality work and the best quality map on my engine.... however the proof will be in the pudding.
there may be an opportunity for some interesting testing on the engine aswell, will just have to see if things pan out
Edited by nickz32
For those of you interested, here is a good video about the Superflow SF902 engine dyno
Under stressed engines always last so long so will be really interesting to see what the final set up is and a build spec list one day.
So what kind of gremlins as an example, were you having with the current set up?
This is all quite interesting to learn really, before I start building my engine!
The full engine spec is listed, probably a couple of pages or so back. I don’t know if you have, but it’s worth going through the whole thread, I detail all the finer details of the build, the hows and why’s throughout.
The limiting factor in terms of peak power is the turbos, which I’m fine with because they will give super quick spool and a really wide power band..... it’s still going to be primarily a road car, so peaky top end power is of no real use to me.
There’s a long standing belief  in the engine building world that if you build an engine as you would a high performance NA engine, the benefits are amplified when boosted (rather than just strapping big turbos on a fairly unimproved long block in terms of valvetrain, porting, etc) and that’s what I’ve done with my engine, I’ve specced the long block as highly as I can to maximise what the turbos can deliver.
Edited by nickz32
Great cheers, I'll have a good read of the build spec then. Yeah agreed top end power no use on the road really, all about response! Keep us posted, looking forward to the updates ?
Having scanned back through a fair few pages, it appears that I haven’t written an up to date spec of the car for some time.... so here goes...
Engine spec
88mm CP forged Pistons, Diamondyze anodized black
Saenz Forged Con Rods
King XP main and big end bearings
EP Racing Thermal Barrier Piston Coating
EP Racing High Performance Bearing Coating
EP Racing Billet Crankshaft Cap kit
EP Racing High Capacity baffled Sump v2
ARP main crank and head studs
EP Racing modified crank
EP Racing modified oil pump
BDE oil tree
Improved Racing remote oil filter housing
Dash 10 braided oil lines with AN fittings
Setrab 23 row oil cooler
ATi Super Damper with EPR trigger wheel and Hall Effect sensor
Ross Performance Camshaft Trigger Kit (CAS Elimination kit)
EP Racing “Street” profile CNC Head Port
EPR “street profile” 3 angle CNC cut valve seats.
EPR Genesis 1 camshafts (272 deg 10.1mm lift)
Manley 1mm oversize valves
SuperTech dual coil valve springs and titanium spring retainers
Solid lifters (replaces hydraulic lifters)
Ferrea valve guides
BDE v2 intake VTC pulleys
BDE v2 exhaust pulleys
Power Enterprises Kevlar timing belt
EP Racing belt tensioner
AMS exhaust manifolds - ceramic coated
Z1 GT525 turbos, modified with enlarged wastegate port - ceramic coated
AMS 3in expansion down pipes - ceramic coated
Custom 3” stainless steel exhaust system using Vibrant resonators and silencers and stainless steel V-Bands (yet to be built, but have the parts)
AMS smoked timing covers
Zspec fasteners
WinFactory top feed fuel rail with Injector Dynamics 1050x (1065cc) injectors
2x APEXI air filters
Concept Z Performance 2.5” intercooler piping
Z1 motorsport 2.5” intercoolers
HKS SSQV4 dump valves
TRANSMISSION
SZ segmented flywheel
RPS street max
350Z clutch fork and chromoly pivot
braided 1 piece clutch line
Bronze linkage bushings
FUEL SYSTEM
Dash 8 stainless steel braided fuel lines from tank to rail with AN Fittings
Billet fuel pump hanger
Ti Automotive 525lph fuel pump
TurboSmart FPR2000 fuel pressure regulator
FPCU bypass
ENGINE MANAGEMENT
Haltech Elite 2000 stand-alone ecu with associated sensors
Haltech WBO2 Wideband controller with associated wideband sensors
Haltech 4 port CAN-BUS module
Haltech 12 position map switch
Haltech 3 bar MAP sensor, boost solenoid and IAT sensor
AEM 150psi fuel pressure and oil pressure sensors
CHASSIS
Varrstoen ES2 wheels (18x9.5J front 18x10.5 rear)
Brembo front and rear calipers w 355mm discs
Braided brake lines
CZP rear subframe locking collars
Power trim front camber arms
Tein front tie rods
NISMO front tension rods
Whiteline Suspension rear camber arms
Whiteline Suspension Anti Roll Bars (front and rear)
BODY
Stillen GTZ front valance
Twins brake ducts
Stone guard finish removed from sills and back bumper and smoothed
Rear arches flared
WinFactory CLS-R spoiler
Carbon fibre scuttle panel
New Nissan roof and door mouldings and rubber seals throughout
Full “glass out” respray in original KH3 Super Black (original colour)
INTERIOR
OMP dished steering wheel
Defi oil/water/boost gauges
Blitz turbo timer.
Edited by nickz32
  • 1 month later...
Yeah, unfortunately it has been halted yet again......
the Elite ECU has been sent back to Haltech for inspection.... the best way to describe the problem is that the Elite thinks the ignition switch is being turned on and off rapidly, which in turn is triggering a safety mode that stops the engine revving past 5000 rpm.
one of these days everything will go smoothly
With the engine on its way back home, it’s spurred me on to sorting other bits and bobs on the car.
the first was an irritating problem of the interior lights staying on regardless on door being open or closed. Even with the lights turned off and the boot light unplugged, it still drained the battery after a couple of days. I’ve had this problem since the car came back from the respray.... which was the first source of confusion as they didn’t remove anything that should have effected this electrical circuit
After lots of checks, many messages with JoelyP, I managed to track the problem down to the boot switch. On removal and inspection the issue was obvious. The boot release hand had been pulled too hard, bending the mounting bracket. This meant that the rocker arm that breaks the electrical contact wasn’t getting the nudge it needed from the lock mechanism. A quick tweak on the vice and it was good as gold.
I can only assume that whilst in the body shop when they’ve refitted the boot they’ve had an issue with the disengagement of the lock and pulled the lever too hard.
On 19/03/2021 at 23:27, AndrewG said:
Looks like you had a similar problem to Richard:
Yup - looks like the same issue I had.....!
Even with a brand new OEM boot catch, I still had to bend the lever slightly, so that it didn't keep tripping the circuit every time the boot lid jiggled as I drove over the lumpy roads around here.
If it keeps happening I might look at reinforcing that section of metal to stop it from bending. It looks like there would be plenty of room to weld a triangle on the back of it that should reinforce it sufficient
Hopefully the first of many parts deliveries turned up to day.
My Haltech elite managed to win the race with my engine and turned up first, aswell as the exhaust tips for my custom exhaust system
These are APR TPK0006 exhaust tips. They’re 3.5” slash cut, double walled tips originally intended for APR’s Mk7 Golf R exhaust system. I think they should look bloody awesome.... not too big like R35 GTR tips but big enough to nicely fill the space in the back bumper. They weren’t cheap, but they’re REALLY nicely made, pics don’t really do them justice
More goodies today!
First up, I bought and fitted these Forge Motorsport’s turbo blankets. These tied with the ceramic coated hotside (manifolds, turbine housing/downpipes) should do a nice job of keeping engine bay temps down... whether there’s a performance benefit, who knows.... there has been a few papers published to suggest that there is, but I’m more interested in increasing the longevity of the hoses and loom around the hottest parts of the engine
Then I got home and found more goodies had turned up.
My back boxes turned up, Vibrant Street Power silencers (3” inlet 2x2.5” outlet).
they’re REALLY nicely made and look awesome with the APR tips.... can’t wait to hear what they sound like
