Bovs
So, my stock recirculating valves are shot now. What options do i have? Can i get stock ones at a decent price? Any particular aftermarket ones i can go with? I would prefer staying with recirculating valves as i have no interest in the sound. Any suggestions guys?
http://bde-performance.com/goose.htm
Do not fit blow off valves ....no no no repair your recircs
Jeff
As above. BOVs as well as being hateful do not add an ounce of performance or anything and 'can' be detrimental.
I have GHKs on my Z. All that lovely metered air stays in the system as it should.
Yes perfect !
Unfortunatelly mine are broken because of rust. Straight through :( so rebuilding is not an option.
Bailey used to make a recirculating valve called the DV30. Not sure whether they do it anymore. I know Joelyp had also found another manufacturer of aftermarket recirculation valves.
I'm pretty sure there is a way of turning an atmospheric dv into a recirculating one.
As above. BOVs as well as being hateful do not add an ounce of performance or anything and 'are' be detrimental.
Better!
HKS do a 'kit':
http://www.sumopower.com/product/hks-ssqv-recirculating-fitting-19mm-71002-ak003
this is the aftermarket recirc JP was looking at:
http://www.ebay.co.uk/itm/GFB-Mach2-Recirculating-Dump-Valve-35mm-inlet-30mm-Outlet-for-Subaru-WRX/371792851392?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Edited by AndrewG
