Driftworks Front Adjustable Lower Arms Help
ok,
Answering my own question here but i'm presuming its a safety feature to stop the steering control arm hitting the arm.
EDIT.
To stop your wheel hitting something that's not suppose to, by adjusting the bracket in or out it limits the steering.
Great team work on this, thanks :)
Edited by JaiKai
i was thinking of getting these but decided to refurb the old standard ones instaed a pic of these fitted would be nice to perhaps change my mind! :thumbup1:
dan.
I'm heading over to the garage tonight to fit the other side of my suspension / arms / brakes and wheel.
I'll get some details pics.
I've used them before on my last build and I thought they were great, along with the geomaster version of the front arms it gives more clearance behind the wheel.
dan.
looks great :thumbup1: think gonna start my Christmas list early!
dan.
How much are these? I was thinking of doing something similar. Also is it a lower arm kit or an upper kit too?
Depends what you want to do.
I've went for a full complement of parts and redone nearly everything :
Rear Traction Rods - £89
Rear Camber Arms - £119
Rear Lower Arms £215
Rear Toe Rods - £129
Rear HICAS Eliminator - £179
Front Upper Camber Arms - £179
Front Lower Arms - £199
Front Geomaster Tension Rods - £119
Front Geomaster Tie Rods - £79
Individually they are expensive but they do sets if your planning on buying a few of them.
Also 0% interest free option over 12 months which I took as I had so much stuff.
Over the winter was was thinking of removing all my suspension and upgrading it. means I can check for rust and get some waxoyl done too. Mine is an NA so I wouldnt need the hicas kit. do you have a website/link for parts or just a simple google will suffice?
