Replacing injector no 1
I'm going to attempt an injector replacement, it's no.1 injector (by oil filler). Has anyone removed and replaced this without Dremel work? It looks like by removing the throttle cable bracket, that it should be doable.
Thanks Andrew, I'm going to replace all of them with 740s by the end of the year along with a new harness and chip. For now, it's just to get it running correctly.
Yes Gary, it's open circuit unfortunately, so needs replacing.
I know, I was actually thinking of between now and then and in particular September.
No dremel required for No 1, see my link below with pictures >>
https://www.300zx.co.uk/forums/showthread.php?172124-Injector-seal-fail-tech&highlight=injector
Jeff
[ATTACH=CONFIG]107236[/ATTACH]
Thanks Jeff.
September will likely be the old injectors.
Still waiting on my new starter motor and starter harness. Those have had to come from Japan.
Managed to get the screws and cap off, but, try as hard as I might, I can't get the injector out of the rail.
Any tips? No matter what method I use for bracing, it won't pull out.
It will probably break into bits as you remove it. Make sure you install the new one correctly.
Son of a whore! It popped eventually! Won't be able to self-gratify for a while however! My wrist! God damn it! Lubed up the new one, popped it in and reconnected everything else, she's now runnin' on 6 again!
Nice one Si', always a satisfying moment when you find, and then go on to fix a tricky problem.
:thumbup1:
It is! Frustrating as my Z has never really suffered with problems until now so I've never had to fix any electrical gremlins on it before. Glad it was injector 1 that had failed.
I can tell you that when one of mine failed, another two failed soon afterwards,
I bought a used set of injectors and sent them off to be flow tested and refurbed, and then fitted them, just food for thought.
They can all be replaced without removing the plenum but you'll need a dremel and the right tools to remove the screws without rounding them.
I thought that might be the case. Gonna ohm test the injector initially
Membership No 0780
INSURANCE GOOFA
