Idle control valve adjustment
My 300 has always ticked over at about 950rpm so I'm looking at slowing it down a little ,is it in or out to slow it down ?
Also do I have to turn the car off then on again for it to re- adjust
You need to warm it up first then unplug the connection and set it to iirc 600rpm, upon replugging it will pop up to 750rpm. You should check the throttle position sensor, timing and for boost leaks first. Mine sits about 850/900rpm, but I know my base timing is wrong for idle as such due to the neutral switch buisness with the conversion.
Cheer's Steve I shall have a look I don't think i have any leaks but you never know
I can't remember, you do it the engine running anyway so you will hear. You can turn it quite a bit before it goes mad.
Sounds a bit hit and miss to me ,I may leave well alone as its always been like this even after it had a spell at zedworld
Shit ,,so do I screw it in or out to lower it
In I believe.
It doesn't take much mind.
Information herein:
https://z32.wikispaces.com/Idle+Control
All went very well, tick's over perfect no leaks and I didn't even drop the clip on the plug
cheers Andy and Steve
