1990 twin turbo manual
Got this 1990 twin turbo manual for £250 last year and been slowly doing bits to it when i get a chance
Looked like this when i got it
Bought a dent puller for in work and pulled the dent out on the quarter
While the filler was out i sorted the bonnet too
Swapped the bent lower arm a few days ago
Car wouldnt rev over 3k as its missing the intercooler so bodged up some pipework inplace so itll come out of limp mode
  • Replies 35
  • Views 3.2k
Sold the wheels off the car and while putting it on stands i saw this pipe
Im guessing something to do with hicas?
The new wheels to be fitted when the new nuts turn up
A pipe from outside that routes into the stock exhaust to get better emissions. Cheating really :P
You can remove it or forget about it
Ill have a look over that when im sorting a few bits at the front
It goes into the front wings fyi
Yep drivers wings already off saw some rust on pass side so thats coming off too
Fitted the new wheels today and took it for a quick drive round the yard to check for any rubbing issues and found the car to have very little power
20170527_153442_zps3pjn9vhk.jpg20170527_153404_zpsjyhcan1b.jpg20170527_153414_zpsqahvyvkq.jpg
Need a spacer on the front as wheels are just touching the caliper only enough to scrape paint but its enough
  • 2 months later...
TDM works;
[ATTACH=CONFIG]105672[/ATTACH]
just looking at intercoolers, where does the air filter and maf go with this set up?
That's up to you really.
