Steam Cleaner
A normal pressure washer using TFR in the feed will do it
You could pre-treat with neat TFR in a sparay bottle.
Or pre-treat with Jizer sprayed on neat and left to soak a few hours..if some parts were really bad.
Blow it all dry with air line and finally with panel wipe in a spray gun.
IMO of course
or use a household steam cleaner instead of a commercial one, which may take a bit longer, but you probably only need it to remove the stuff that TFR or similar (M/cycle brake/chain cleaner is good) doesn't get off first?
