Subframe bushes, removal - Options?
I have a spare sub frame that I'm going to get powder coated and swap the bushes out for new Poly ones. Looking at the various "How to's" on the subject. would those of you who have done this recommend getting the new poly bushes that come with the outer sleeve, like these form CZP?
https://conceptzperformance.com/czp-subframe-sleeve-kit-w-energy-suspension-bushings-nissan-300zx-90-96-z32-55400-74102_p_3146.php
It sounds like the worst part is actually cleaning the left over rubber off the outer sleeve, once the inner sleeve and rubber goo has been removed. (I was going to burn them out, as per the many videos on the net show)
As an aside, has anyone here actually fitted SPL solid mounts on the sub frame or diff? If so how bad is the ride/noise?
All advice welcome, Thanks
  • Replies 38
  • Views 3.4k
I can tell you've already got locking collars from reading another thread, do you really want to spend hours removing the old ones compared to a 5 minute job putting locking collars on? Burning them out is the way people do it at home but remember there is a metal collar around the rubber, so once you've burnt and cut out the rubber to get the centre section out, you will have to carefully hacksaw the collar and try to pry it out. Its probably a 1hour + job per collar, so if you feel like new bushes are the way to go... go for it.
I know Mantav8 and Dan_300zx have removed them so it might be worth their input of poly vs solid compared to locking & how hard it was.
Edited by Alic
burn them out them remove in inner skin then fit the new poly bush when i did mine there wasnt a metal sleeve that came with them looks like they have changed the kit a bit.
here the pics of mine
I have the solid sub frame and diff mounts, James did the hard part in that one for me. What I can tell you though is that there is a definite noise transmission through them and you will feel the diff back lash on hard over run. I can't comment on that versus Poly. What I can say is that there is NO play with the solid mounts when refitting the frame and I had a mare joggling the frame home.
are you using solid dif mounts to? i have full poly polly bush inc the diff. and there is some back lash from the dif are you using a single prop. i dont really really hear much noise from the diff now i have the interior back in, i think a combo of polly sub bushes with stock diff bushes and stock prop would be the best bet for less lash
Two piece prop, solid diff and solid subframe. Yeah the sound is noticeable but not annoying with an interior. I drove it with a stripped boot and you could hear it full chat over the exhaust, was like being followed by a jet.
i dont get it that bad i dont even notice really now
[ATTACH=CONFIG]102090[/ATTACH]
What sway bar is that mate? Is it much better than the stock sway bar?
Edited by Alic
stock uk bar so its thicker than a jap one
Thanks for all the replies guys. Really appreciate it.
Dan, the kit in the link above was including a new outer sleeve as many people remove this, not realising that they need to retain it, if fitting new Poly bushes.
I think I will go with Poly bushes on the sub frame and diff mounts.
I have already started getting the old bushes out, (yes they are a barsteward to remove)
The good thing for you Howard is that it's a spare subframe, so you can go at it for a while until you're fed up and you can then walk away from it till another day when you're back in the humour for hardship:thumbup:
I had little difficulty in swapping out the diff bushes, blow torch made short work of them:thumbup:
Yes after 2hrs last night Richie, I had had enough, especially the smell of the burning rubber!, I'm doing it in the garage and that lovely smell can work it way into the house, which Mrs B isn't very impressed with :scared:
Pressing out old bushes & replacing poly ones requires a fly press ( I think that's the name)
From what I remember it was the front ones!
Some people use a hydraulic press, but when they are 20+ years old, corrosion makes them welded in there so often easier to mutilate them from what i've read.
AH HA HA HA HA!!! Do it in the garden mate, that's what i did:thumbup:
no wonder the mrs. is mad at you, the house would smell like a bonfire at a pikey camp at Halloween!!:lol:
I did the subframe and diff bushes in a day with help from a mate a few years back. I fitted the poly bushes rather than solid after talking to and taking advise from many who had done both.
Can't remember where I bought the kit from but think it was Z World or similar. The kit came with outer steel shells and seemed to be the most comprehensive solution leaving nothing of the old to go wrong. Just my OCD I expect but wanted to do it once and only once.
All I would say is that it's a full days work from driving in to driving out but the results are well worth it.
The sound is a little more "raw", a bit more race car but not annoying at all. More a feel thing to me.
I was advised that unless tracking the car, the solid were a bit over the top.
A fly press would be great but some thread bar, various sockets and nuts will get you there.
Need to take care as the front and rears on the subframe are from memory replaced in a slightly different way.
Remove the guts of the bush and cut the outer sleeve with a hacksaw carefully. Then fold inward and cut again if required. Taking your time is the key to success I think with these.
Obviously get the powder coating done before fitting the new bushes and make sure the holes are properly blanked off as any powder in there is a nightmare to remove before refitting new steel sleeves.
Edited by Dipstick
Thanks for the reply and information.
I will keep an eye out for getting the front and rear bushings round the right way.
  • 1 month later...
Well a little update. I removed the old bushes, what a pig of a job, that was!
Should be collecting the powder coated frame tomorrow, then just need to finish getting the old one off the car.
Edited by bigh
I've removed 4 sets of subframe bushes now .I use a good quality hole cutter both sides to remove most of rubber and centre tube then hacksaw thew bush case but don't cut into subframe.Then chisel bush in on itself folded in and hammer it out .Ive done all 4 in2 hrs .
Well today the subframe was finally removed from the car, not to bad once everything was out the way. Nearly missed the 2x feeds from the top of the diff, that go to the oil cooler, but seeing as I am going to remove it anyway I just cut the hoses to the cooler.
Tomorrow I will start remove the control arms etc so I can get all the parts powder coated.
Oh sorry, neither of mine had any diff cooler lines or an oil cooler.
Also what happened to the HICAS on that? It looks absent, but there is no lockout for it
Already remove the HICAS Alic, jusr prior to dropping the subframe. A nice new Driftworks lock bar is going back eventually.
Still a long way to go as I will be replacing all the rear brake lines at the same time.
No worries about the oil lines, I saw them before I went to far, just couldn't get to them until the frame had dropped slightly.
Well on the way then Howard,those brake lines should be easy now whilst its all apart.Quite a weight all that lot to lower down isnt it !
Brings back memories.
I too had to replace all of my rear brake lines not to long ago.
As Jimmer says, a lot easier with the sub frame out of the way.
The diff alone weighs more than a small planet. :lol:
