JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 124.3k
  • And they have arrived !
So while my battery is charging i'm moving on to my next issue.
Bleeding the clutch.
I have a straight drop clutch line but with fluid in the reservoir no matter how we do it nothing flows to the other side.
Its a new cylinder so is there a way to adjust the pump action ?
From inside the car i can see the valve moving in but no fluid goes down the line.
Clutch booster and pedal back out along with the master cylinder.
Fitted everything together externally and i've managed to bleed the valve when not connected to the booster or pedal.
Basically stuck the master cylinder in a vice and pumped it with a socket screwdriver end.
I'm going to assemble it all again external to the car and try it out now see if the piston moves.
The problem is when i put it back in the car it stops working and i think i may have sussed it out.
This being an ex auto, we had to take off the faceplate covering the clutch area inside and out.
And i beleive looking at this the rubber membrane covering the bulkhead may be getting sandwich between the master and booster.
The extra gap is enough to stop the piston working,
Hmmm. I wonder how common this is with auto converted cars?
not sure,
This is the second conversion i've done, but i dont remember having any sort of issue previously.
As you can see on the picture the rubber parts would get sandwiched between the booster and master cylinder.
I just need to cut a larger circle of the rubber away to give more of a flush and flat seal.
So the problems i'm having in general is either power or fuel; or both.
I nipped out to buy 5l of fuel as when i popped off the fuel pipe next to the fuel filter there was no pressure.
The battery i have is brand new but i think all the testing lately has run it down too far.
I'll charge the battery back up tonight and try again tomorrow.
cant find anyone yet, but saying that what use would it be if it wont start.
I’m keeping the faith that you will get it sorted and make NEC.
