JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 124.5k
  • And they have arrived !
I have a few more days before the concept order arrives so over the weekend I cracked on with a few other jobs.
First was the entertainment, fitted my speakers, new dab antenna and new pioneer radio.
Not any pictures here as they are just the base speakers I could get for little money, but the stereo is digital and has speaker phone built in which is needed.
Next issue to resolve was my hand brake; which was near non existent.
Off comes the rear wheels which surprisingly were held on with just hand tight bolt; oops.
It took me a few attempts to work out the procedure to fix the hand brake but I got there in the end and now its tight enough on both sides.
After I fixed the hand brake, I did a quick check on a few things and then discovered loads of loose bolts.
The brake callipers were bolted on near thumb tight and the main bolts securing the hub never had any cotter pins.
Crazy wee things like that will end up with a MOT fail.
Next thing to do is bleed the brakes but i'm needing to buy or make a bleed kit and also get somebody to push the brake as I do it.
Go and buy a new oil can,Get some windscreen washer clear pipe and back bleed the system squirting fluid back into the sytem.It will save loads of pumping.
So I think my new build finally has a name.
Done a quick search and no one that I can see has used it previously.
Two things bring the name to mind and even though its a masculine name its been used for females too.
First is the name of a computer in a sci-fi tv series (not hal)
Second is the name of a character created by a famous British singer (now deceased)
Any ideas ?
How about “Ziggy” from Quantum Leap?
Ziggy Stardust aka David Bowie
Got it in one!
Cool name Lee :thumbup1:
Looks like you have nodded off.. :lol:
Seriously though, truly stunning work mate.. :drool::tt1::thumbup1::thumbup::yes:
I would if i had one :)
You have come so far Lee, there must be one available somewhere. (Ha'porth of tar and all that)
Recently Browsing 1
