Cruise control actuator plug
Could anybody tell me where the cruise control actuator plugs in under the bonnet. My car is made from 3 different zeds. The shell is a 1990 jdm import. The engine and harness are from a 1995 import which did not have aircon. Any help would be greatly appreciated.
That's what I thought, is it possible that it might have fallen down low during engine swap. mine must have aircon as I distinctly remember undoing that oval plate on bulkhead with two large pipe nuts to install engine loom.
Sent from my SM-N910F using Tapatalk
Top left by the BMC. Usually gets tucked down. From memory is a square grey plug.
Sorry, silly me, brake master cylinder. I will have a good explore tonight. Do you know what loom it's on??
Usually wrapped up with tape to the left back side near the small fuse box.
But not all zeds have cruise and it can't easily just be added in. :(
Sorry, don't know why I've ended up talking about air con. I will take a look and see if it's buried somewhere below. If it's part of the engine harness that would explain it, as it's out of a vehicle which didn't have cruise
