tuning and remapping advice
i have a small issues so want to see what others think. the car will be on the road soon next few weeks. since its been off the road its had fitted bigger turbos the same as jtw gt500 fill 3 inch system form down pipes to back boxes will be fitting the duel maff and stillin translator this week and the 555 injectors. before the car came off the road i fitted a generic chip and turned the boost up to 14 psi that chip is still in the car. now i know it will need a remap to run with all the new uprated bits, but i need to bed in the clutch first it had a 800 miles bed it time. if leave the boost turned off just running actuator level of boost with the chip thats in now and all the mods in the car now including the bigger injector will this be safe or will the ecu be confused and or will it be over fueling to death some imput would be great here as am not sure really the best road to take
At the very least you will need a chip to suit the injectors, without that I wouldn't even start it up. Ideally the car needs a base map then finishing off once it's bed in.
^^^^ This.
If the Ecu isn't mapped for 555's, don't even think about starting it until you have a 555 base map
i could leave the stock injectors in till the clutch has bedded in then fitt the 555 and remap then.
just means i will need to remove the plenum 2 times or like you say get base map chip with 555 tuning on it
Lee Dent can do you a generic chip for your 555s based on your setup and it won't break the bank [emoji106]
do you know who makes the maps on the chips ? and were is noel nowdays
can i get a straight answer who can i trust to get a 555 chip and who can i trust to map the car. no name and shame just the info who can we trust the only name that keep popoing up is greg at pro tune
As far as I'm aware Noel is still trading, but he appears to have moved away from the club. You can buy generic chips from specialityZ. If that's the name that's pops up maybe it's best to speak to him.
Gray is having a Wolf ecu installed and mapped at Tuning Developments in warrington.
Edited by Iangreenfield
I'm in the same boat. Will be leaving my injectors out to prime/test the engine at idle once my new turbos are on,
As for mapping I keep being recommended Greg at protuner,
keep away from them google and have a look for your self had some very bad feed back and have messed a lot of cars up
Edited by dan300zx
yes his mane keeps poping up i have looked hard in to each and every tuners his is the only one i cant find anything bad about seems all positive
so after a talking to a chap am using run the car with the stock injectors boost off bed the clutch in then fit the injectors ship car to him and remap job done
Edited by dan300zx
And who is this chap ?
greg at pro tune cost 3 times as much but thats were am going
You said no name and shaming...:whistling:
I'd be wary of buying a chip stateside due to the types of fuel used over there. I've also heard good things about Greg, definitely worth getting in contact with if you're going for a custom map.
Wary yes. But you can really be quite selective. Speaking to them as I've done, you can select things like fuel octane etc.
yes sorry. let keep to who can do a good job
i did see some mite have been on z1 there not octane rating was 93 i think
Have a look at SpecalityZ Dan and pop them a mail explaining what your after.
i was going to but after talking ti greg today he say just leave the boost off leave stock injectors in an just drive it to bed clutch in them fit the bigger injectors and then map kind of makes sense
Nothing wrong with that Dan after all your efforts you need the best tuner you can to do the job properly
will i have spent many many hours well 3 weeks in fact looking into mappers and tuners i did a lot of digging a found out whats what pretty scary really when you dig deep whats you find i had no idea just how bad things are here in the uk when it comes to mappers pretty socking really
